Question about Brother IntelliFAX 4100 Laser Fax
PRINTING ONLINE I cannot receive faxes and the screen says PRINTING ONLINE. Sometimes unplugging the device for a few seconds and plugging it right back in will enable a few pages of sent faxes to print, but I know there are many more that are trying to come through. How do I clear the memory, provided that is what is needed to be done?
  • 22 Answers
Unplug the power cord from the back of the machine for 30 seconds. Put your finger on the stop key first and then re plug the machine, hold the stop key until the time and date return to the LCD. Do not worry about losing any faxes the machine can be powered off up to four days without losing faxes in memory.
Posted on Oct 09, 2007
SOURCE:
My company lexmark X642e all in one machine was faxing fine. I unplugged the fax line and plugged into another fax outlet plug and it would not work so I plugged back into the original fax line outlet and...
Make sure you plugged it back into the right port on the printer itself. The one I have actually has two different phone line plug-in ports - one is for the FAX line that connects to the wall. The other is so you can attach a separte phone as an extention to talk on. Good luck. Also, after it is plugged back into the wall, did you power down, wait 30 seconds and then power back on? Sometimes these things need to recognize at start up whether or not they are connected to other devices, etc. Good luck.
Jun 17, 2011 | Lexmark X642e All-In-One Laser Printer
Will not print fax's
1. Unplug the fax machine from the power outlet.
2. Press and hold the "Stop/Exit" key, then plug the power cord back into the power outlet.
3. Continue to hold the "Stop/Exit" key for 5 seconds. The display will return to date and time.
4. If the display does not return to date and time, please repeat the process to make sure the procedure was completed correctly.
May 20, 2009 | Brother IntelliFAX 5750e Laser Fax
Display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Feb 11, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Not printing, but says it is
I have a fax machine with the sam problem, what i did to resolve the issue was removed the 3 screws and removed the back cover, disconected the battery then removed the cover over the parallel port. I then disconected the 5 connectors on the right towards the rear of the printer 4 white 1 red, reconnected the printer to power with the connectors disconnected, then after 30 seconds i unplugged the printer reconnected the cables and it worked, has failed since
Jan 19, 2009 | Brother IntelliFax-4100e Fax
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Won't receive or send
Try hitting Menu * 2864 (it should say maintenance) then 91 then 99
This will reset the fax machine without erasing your settings. It should clear it up. If it doesn't work after a few tries, you have to hit 0 instead of 91 and that will reset the entire fax machine to factory defaults.
Feb 20, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Printing Online
i had the same problem, got this solution from brother and it worked!
unplug the fax machine
press and hold the stop button
while still hold down the stop button, plug the machine in
continue to hold down the stop button for 5 seconds
Feb 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Printer not printing
Try unplugging it or pulling the power brick out of the back, wait a few seconds, plug it back in, and then turn it on. It might have something stuck in its memory.
Aug 21, 2007 | Lexmark Z1420 InkJet Photo Printer
Brother IntelliFAX 4100 Laser Fax Logo
271 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
