Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Gigabyte K8NS + shutdown problem
Don't know if it is a software or hardware problem, but my guess goes for hardware. When I close my computer (from windows) everything goes well , the video signal turns off , also the supply LED but the coolers won't stop, pushing the restart button is useless cause the computer is somehow turned off but the supply voltage is present at the coolers. Tried an clear CMOS operation using the jumper near the BIOS chip (with no supply of course) but this didn't solved the problem . P.S. same problem when "long pushing" the supply button THX and excuse my english
    Sergeant:
    Champion:
  • 293 Answers
Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS Test it first by Shorting the connections in the motherboard. Use a Flat head metal screw driver. Be carefull though. A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver.
Posted on Sep 22, 2007
Gigabyte k8ns pro Drivers sm bus controller
It would be hard to look for that driver manually. It would take a lot of time. If you want it automated, then I suggest that you install RadarSync. It will look for the drivers that your computer needs including Gigabyte k8ns pro.
Jan 24, 2013 | Computers & Internet
GA-K8NS losing Cmos - not the battery
Hi, you can download drivers and software here:
http://www.gigabyte.com/products/product-page.aspx?pid=1783#driver
Try to change the cmos battery.
When the battery run out of power the bios can`t
remember its settings.
Thats probably why you have a cmos error.
The battery is a 2032 watch type.
You can try to remove the battery and measure the voltage
with a voltmeter.
Its should be around 3 volts.
Consider to upgrade the bios when you get it up and running.
You have to make sure its the right mainboard when you flashing
the bios or the mainboard will be destroyed.
Sep 07, 2011 | Gigabyte GA-K8NS Motherboard
My pc is making a alarm tone sporadiclly and will sometimes shutdown and reboot.I found that by wiggling the harness of wires inside ,the tone alarm will stop..but will start again . Any idea? MB ...
That tone is a warning code.Go to the manufacture websight and look for error tones or codes.
take side cover off and secure all wires and make sure everything is plugged in correctly.
Jan 06, 2010 | R.A.M. Computers Gigabyte GA-K8NS...
Boot problem
Gigabyte GA-K8NS in 80% breakages have burned chipset. Repair only with replaced (solder) it.
Nov 03, 2006 | Gigabyte GA-K8NS Motherboard
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
