Question about Keurig Elite B40 Coffee Maker
Descale solution? Descale solution...whare can I get it? Is there a home remedy? Clorox? I see someone used this...is it safe? I have model B-40 Thanks
    President:
  • 1,489 Answers
Clorox is a basic chemical -- what you need is an acidic chemical to dissove the lime. White vinegar will work, but nothing works very well (not even descaling chemicals), you'll have to treat it several times.
Posted on Apr 21, 2009
Forgot what formula to use when trying to open safe with keypad
need to know wht safe your trying to open. model number make etc. or youtube it they have tons of answers there. even how to open someone else's safe.
Oct 16, 2017 | Formula Home Security
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
Aug 17, 2014 | Keurig Elite B40 Coffee Maker
SCOTSMAN MODEL #CME506WS1F
You need to descale the water circuit according to manufactures instructions. Scale build up keeps the ice from releasing during harvest cycle. If overall ice thickness is to thick, rotate the ice bridge thickness screw at the top of the platen countercloclwise about 1/8 of a turn max between freeze cycles until desired thickness obtained. If you do not know the correct descale solution alway use a nickel safe descaling solution.
Dec 03, 2012 | Scotsman Ice Maker WBin Flake Style water...
Mouse Body Is Sticky How Do I Clean It?
I had the same issue and using clorox wipes only made it worse. I eventually used Lacquer Thinner, which is usually a mixture of solvents able to dissolve a number of different resins or plastics. It can be purchased at most home improvement or hardware stores. It worked perfectly.
It is a bit of a messy process and there are fumes. I wore rubber gloves and did it in my garage using several paper towels. I also recommend applying scotch tape to the edges of the non-rubber areas to protect the finish. Also avoid getting it on the bottom of the mouse.
Jul 26, 2012 | Microsoft Wireless IntelliMouse Explorer
How do you treat an infected eye using a home remedy?
Put orange juice and dishwishing liquid in it, it'll be fine after a two or three hours(!)
Serioulsy, I don't think you can treat an eye infection with home remedies. See a doctor, or at least, a really good denist. It's close enough(!)
Nov 23, 2010 | Health & Beauty
I have a Kenmore Elite Model 106.57863801 side by side stainless steel fridge. The doors squeak when opening and closing. How can I remedy this?
Good day,
Spraying a good lubricant on the hinge pins should solve your problem. Sprays like WD-40 shouldn't be used because they may come in contact with your food.
I suggest you call around to your local appliance parts houses to see which one's carry a "food compatable" spray.
It's safe to use around food and can be saved for future use. Most service techs I know carry it with them in the service truck to use when needed.
Oct 05, 2010 | Kenmore 73503 Stainless Steel Bottom...
Is vinegar OK to descale a gaggia classic?
If you use citric acid on the Classics aluminum boiler you are risking
serious corrosion. To descale an aluminum boiler you need tartaric acid
based descaler.
  • but it is safe to use CleanCaf as a Descaler--Dissolve in water reservoir, run pump.
  • also it is safe to BAckflush the machine with Cafiza/Joe Glo/PulyCaff. NO detergent gets in the boiler. it is impossible.
  • dont use vinegar.
This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | Gaggia Classic Espresso Machine
How do i get mold out of the diswhasher? Is it
I would try Hydrogen Peroxide first before the Clorox type.
Do not use CLorox WITH the detergent at the same time.
You could also run a very concentrated detergent dishwasher load.
Oct 19, 2009 | Frigidaire Dishwashers
How do you descale the keurig B40
use descaling product not vinegar ,vinegar remove calcium in little piece descaler melt calcium 1 part descaler 1 part water fill water container start machine for a few second turn off let it seat for 15 minute repeat untill empty to reset the lightnormally its maneer of pressing the on button
i get back to you on that one pierre
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
1,094 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
