Question about Ovens
Can't find the fuse for the oven
Hi. The oven in my tenants flat stopped working. The hotplates are still fine. I assume it's a fuse that's blown but can't seem to find a fuse anywhere... It's a KIC electric oven (no model number or anything that i can see) Any idea where i can find the fuse?!
    President:
  • 1,489 Answers
I doubt this is a fuse problem. Could be the heating element has failed.
Posted on Apr 21, 2009
Belling classic 900e grill & hotplates not working
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Dec 13, 2013 | Belling Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
How do i reset the oven after a power failure?
If your oven won't heat at all, the most likely problem is a blown fuse or a burnt out element. Assuming you're not attempting to repair an antique, your oven will have a clock. If it has also stopped working, it's safe to assume the oven is not getting electricity. Check your circuit breaker box and reset the breaker if necessary and see if this fixes the problem. If not, cut power to the oven at the breaker box before going any further. Note that your oven runs on 220 volts. There should be a double switch on the circuit breaker board controlling power to it. If not, there will be two single switches that need to be tripped to cut power to the oven.
Even if you didn't find a blown circuit breaker, the problem could still be a blown fuse. Some older ovens have their own set of fuses located under the range top, in the back of the oven space, or behind the oven. Inspect the fuses and replace any that have blown with one of the same amperage. Your oven might also have a circuit breaker with a reset button on the control console or on top of the oven that needs to be reset.
If you are still confounded, pull the oven away from the wall. If it is a range/oven combo, make sure it is plugged securely into the wall. If it is a stand-alone oven, inspect the wiring in the junction box to make sure everything is tightly connected and the wiring doesn't show any signs of damage.
Apr 07, 2010 | Neff B1421 Electric Single Oven
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
I HAVE A JENN AIR WALL OVEN AND WAS CLEANING AND MY JENN AIR MICROWAVE STOP WORKING DO YOU HAVE ANY IDEA'S
Check for a tripped breaker or blown fuse in your fuse box. Assuming they are separate units there is no common connection other then the power source.
Good Luck,
Gilshultz
Dec 03, 2009 | Jenn-Air JJW8530C Expressions Collection...
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Ovens
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
304 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
