Question about Samsung YP-T8 Digital Media Player
Headphone jack sound fades in and out when headphone connection is moved
Try cleaning out the headphone jack with a Q-tip and a very small amount of glass cleaner or rubbing alcohol. That seemed to work for me.
Posted on Sep 27, 2007
The headphone socket
When you move the headphone plug around and the sound cuts in and out that usually means that the terminals in the jack have corrosion on them. You can usually clean the jack with contact cleaner that is sold in home improvement stores.
Here's a video showing how to clean the headphone jack on a phone but the process is the same for any device that uses a headphone.
Apr 01, 2015 | Electro Brand Nostalgic Stereo CD Music...
CANNOTE GET RADIO MUSIC NO SOUND
i've just finished repairing one of these Model 88 cd, from Cambridge sound. It also had no audio. I found cracked solder connections on the audio amplifier IC on the amplifier board as well as an inremittent headphone jack on the front of the radio. Try it with headphones, if you get dound try to clean the jack with isopropyl alcohol. a couple of drops inside the jack then insert the headphone connector several times to move the relay inside. Good luck. took me about two hours to resolve this with limited information available.
Sep 28, 2012 | Cambridge Soundworks 88CD CD Player
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
My HD 205 headphones broke last weekend, ive had them for four monthes and when i was listening to music on my ipod touch the headphones sounded like they weren't plugged in properley, i moved the wire...
It sounds like the wires around the jack have become frayed on the inside. If you were to open up the rubber casing around the wires, it would look exactly like that. This is normally caused by improperly wrapping the wires and by not being gentle when plugging them in and removing them. It could be caused by other things, such as electrical damage, but that is much more rare. If you have soldering experience and feel comfortable opening up the rubber casing and working on them, it's not too difficult. You would need to remove the bad portion of the wire and replace it. However, it is just as easy and cost-efficient to have them fixed at an audio repair shop. It should cost no more than $20. Hope this helps!
Mar 28, 2011 | Sennheiser HD 205 Professional Headphones
Hello: I have had my ipod touch for a long time now no problem until now.....i have ipod touch 3G 32gb and whenever i listen to music....and i put my headphones in the jack. If i move the ipod itself like...
smoething like that happened to me. do you wrap your headphones around the Ipod when you're not using it? The connections inside the headset can break if you do that, and if its not the headset, then it is likely that something in the general vincinity of the headphone jack is loose.
Feb 02, 2011 | Computers & Internet
Everytime m headphones move my zune acts like they fell out and stops playing but they didnt so i bought new headphones and found out it was the zune that was acting up........i was wondering if it cant be...
Sounds like the headphone jack has broken solder connections to the circuit board. Mine MP3 player did too.
Fix it with a REALLY small-tipped soldering iron, re-solder the jack connections... not real easy.
Or return/exchange it.
Jul 18, 2010 | Microsoft Zune JS8-00001 Digital Media...
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
No sound
I had this problem as well. I would get sound from headphones but unplugging them I had no sound from the builtin speaker.
When you plug in your headphones it moves a thin piece of metal in the jack which interrupts a connection (this is a good thing) so it can know when to disable the internal speaker. When you unplug your headphones the piece of metal moves back and it enables the internal speaker again.
I was able to fix this by taking apart my x51v and bending the piece of metal a little while the headphones are plugged in so that it will contact better when the headphones are unplugged,
To take your axim apart there are 4 screws on the back underneath the rubber grips that you need to take out. Then you can just slide a finger nail up and down each side to remove the front and back of the casing. The back you will need to swing out from the bottom since it hooks over the headphone jack. I unplugged the small wire that connects the front half of the case to the guts using a tiny flat screwdriver.
Inside on the back, there is a black plastic plate that is held on by 4 more screws. Take that off.
Now you can see the headphone jack. I plugged in my headphones and used a small flat screwdriver to push against the headphone jack on the bottom piece of metal on the right side with the axim face down. You can observe the piece I mean by looking at the side of the headphone jack when you plug and unplug headphones. It moves perhaps 1/32 of an inch.
Your goal is to bend the piece of metal closer to where it is when no headphones are plugged in. The only way to bend it properly is to do it when the headphones are in.
Sorry if this isn't clear enough. I'm not sure if this is a permanent fix or not but it's worked for me.
Jan 04, 2009 | Dell Axim X51v Pocket PC
Headphone issue on Zen Micro.
you have a loose connection on your headphone jack, need to solder the jack back in place.
Dec 07, 2007 | Creative Labs Zen Micro MP3 Player
Samsung YP-T8 Digital Media Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
