Question about Whirlpool GHW9400 Duet Washer
When my Duet washer is not running, it slowly fills with water. This has happened about 3 times.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
The most common problem with a slow filling washing machine is a blocked filter
this is located inside the hose usually near the machine.
it this is not blocked
it may be a stuck valve, to test if this is the case connect the hot water and see if that fills quicker.
a short term fix would be to connect both hoses to cold if you can.
If your machine requires hot water to function it may not fill all the way because it will switch off if there is no hot water.
hope this helps.
Posted on May 07, 2009
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When not in use, my washer begins to slowly fill with water.
you either have a very poor water pressure to the machine or the fill valve is not closing completely and will need to be replaced.
Mar 19, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keeps filling up with water
Hi, the water valve is defective, to make sur unplug the washer 117 electrical corde from the wall and look if it still fill up, if yes then u can be sure that the inlet valve is defective, juste replace the valve and ur home free.. wish u well, Alain
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer
your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
