Question about Kenwood Radio TK2200 TK3200 Compatible Battery
Green light blinks
One of my TH-3200 radios continually blinks green, I tried pushing the scan button but it will not stop the blinking. Also the othere radio beeps when I change channels, is this common? The radios where a gift and work well aside from the green light. Thanks, Mike
On my two channel radio a blinking green light means that it is scanning between the two channels. I can turn off the scanning and the light stops blinking.
Posted on Apr 02, 2008
SOURCE:
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Green Power light keeps blinking and set won't turn on
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Feb 06, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Kenwood Radio TK2200 TK3200 Compatible Battery Logo
851 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jason
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
