Question about Canon PIXMA MP240 All-In-One InkJet Printer
Keeps blinking E3
Canon Pixma MP240 Keeps blinking E3
  • Thomas F. Schneider May 11, 2010
    The below is taken from the fixyourownprinter Website:
    As an "Epson Authorized Service Dealer", there's only so much INFORMATION and HELP that I can legally give to you. At least you will know what your SERVICE ERROR CODE is and the possible problems...A "Error Code E3" is a PLATEN GAP ERROR and is classified as a FATAL ERROR: If you don't turn off your printers power with-in 12 seconds, the printer will AUTOMATICALLY power off. If that happens leave your printer turned off for 15 minutes and then you can turn the power back on. If you don't wait for the 15 minutes and just turn your printer off and back on, the power will not come back on...POSSIBLE PROBLEMS: The platen gap home sensor is defective/bad; the platen gap motor is defective/bad; the parallelism adjustment is incorrect; the platten gap adjustment values are incorrect; the platten gap motor pinion is too tight against the platten gap transmission gear...NOT MUCH HELP I KNOW AND NOT MUCH YOU CAN NORMALLY DO...If you happen to have an AIR COMPRESSOR you might want to take your printer outside and blow out all the DUST/DIRT/LINT/HAIR and small pieces of paper, that normally build-up inside most DOT MATRIX PRINTERS. Just be sure the AIR PRESSURE can be adjusted down to around 50 or 60 lbs of pressure, or you might damage or blow out some parts. After that you can perform any general cleaning that you think might help [wiping off built up grease/dirt/dust/etc] and then simply try your printer to see if you have the same problem, or not...Good Luck! Denny Conway
    Scholar:
  • 85 Answers
Hi. Canon says this
E, 3
Paper jam.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press the Black or Color button.
There is another step to fix this, also from canon.
Issue: ERROR LED: E, 3
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Posted on Jul 29, 2009
Canon pixma MP240: keeps flashing Error E3 paperjam but not paper can be seen inside the printer. Makes noises as though priniting but only puts blank pages through. If power is turned off and...
Hello thanks for using fixya
E3 error is mostly because of paper jam
. their may be small bit paper jam in side.
Even it feels that their is no any piece of paper inside the printer but actually it exist & inside of the printer makes paper sensor & its not function properly
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I have a Canon Pixma MP 240 printer. It's been out of black ink. I installed a new ink cartridge. Now, there's an "E3" flashing on the screen. And it won't print anything.
Error E3 indicates that there is a paper jam.
Firstly remove the ink cartridge you have just installed and check to see if there are any bits of paper underneath that.
Secondly check the rest of the printer for any jams paying careful attention to any rollers as small bits of paper can get stuck to them.
Dec 17, 2010 | Canon PIXMA MP240 All-In-One InkJet...
3 blink on alarm light, husband lost manual for troubleshoot , says its a recoverable error throught computer info
Online manual as requested. Scroll down the page and be sure to select MP240 On-screen Manual (Windows):
Canon MP240 Downloads
Jan 09, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Help
E3 says there is a paper jam somewhere, could be a small scrap, or even a bent or broken sensor lever. Just have to inspect inside carefully.
Dec 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My canon mp240 has the E3 error and it will not go away
The E3 eeror is a paper jam error.
First, Unplug the printer from the power cord. Disconnect the printer cable as well.
2nd, open the covers and using a flashlight, look for any small debris inside the printer. The smallest piece can trip the error. Remove anything you find.
Next, get some "canned air" at any computer or office supply store and blow the inside of the printer thoroughly. You may even turn it upside down so debris can fall out.
Plug it back in to the wall socket and connect to your PC again and give it a try. That should resolve the issue.
Oct 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Where do I load the paper on a canon PIXMA MP240
In Canon Pixma MP240 there is a paper support tab which is in the back side of the Scanning lid. just turn into upright position and pull up to open the input tray.
Aug 23, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon Pixma MP 240 keeps blinking E4
E4 just says the ink is empty, Either your ink is gone , or you have a defective cartridge.
Aug 03, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
2,008 people viewed this question
old marine
old marine
