DLINK DWL-2100AP i connect a pre-congigured AP as repeater, so it should connect me to the main AP with same type and model of AP, the problem is i doesnt provide me an IP address from the main AP, what can be the problem? take note that the wireless connection is established, but give an error of time out while getting ip, we are in same room, so i think its not a prob of bad connction or disconnectivity.
  • dr_oracle203 Apr 21, 2009
    yes, it is turned on, and when i connect to the main AP it give me an ip from our LAN range....
    Scholar:
  • 87 Answers
Reset both of the APs back to factory settings, for starters. From here on, I followed a solution that I stumbled across:
____________________________________________________________
"1) Go to HOME > WIRELSS and choose WDS with AP.
2) Enter the oppsite DWL-2100AP's MAC Address in the first MAC space.
3) Enter an SSID, (this needs to be the same on both DWL-2100AP's)
4) Choose a channel, (this needs to be the same on both DWL-2100AP's)
5) Choose encryption, (this needs to be the same on both DWL-2100AP's)
And click APPLY.
Now do the same on the other DWL-2100AP."
I got this off the forums Mybroadband.co.za
http://mybroadband.co.za/vb/showthread.php?t=49307
You've connected two points and they will now show up as a single wireless connection. Since you've set them up as a bridge, you can have wired devices connect through them nice and easy. In my case, I used them to bridge a single wired connection from a router in one building, into a switch in the other building.
Posted on Jul 29, 2009
    Scholar:
  • 154 Answers
Check whether DHCP is enable on ur main AP.
Posted on Apr 21, 2009
Is there any limit for wireless D-link DWL-2100 AP ?
D-Link AirPlus Xtreme G DWL-2100AP Wireless Access Point provides speed upto 108Mbps, which is the maximum wireless signal rate derived from IEEE Standard 802.11g specifications. However, the actual speed depends upon the wireless network environment, setup and devices.
For further details please refer to DLink Official Product Description
Nov 26, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Getting 169.254...
possibly cat5 cable problem or your DWL - 2100AP is only on wireless mode.
please check and put on mixed mode also.
Mar 08, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Dwl 2100ap
This is the power cycle of death. No way to recover at this point. Send in for repair.
Jan 28, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
Use with dwl-2100ap
What you need to do is configure the dwl-2100AP. You need to login into the repeater's configuration page and go to Home tab, click on wireless on the left. Select AP Repeater under Mode. A new screen will show up. Click on the scan button to see if your router's signal is being picked up in the box. Just select the signal if you see it in the box and put in your security info if you have one.
Sep 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
DWL-2100AP
To use the DWL-2100AP as an access point (repeater), You have to set it up on the repeater mode and type in the MAC address of the router. The best way to do this is to run the AP manager from the cd.
Here is a link to the D-Link support page. Click on product manual from under the Support resources
http://www.dlink.com/products/?pid=292:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Enquiry
repeater, as in a link up for wireless node to node communications?
hmmm...www.dlink.com
check your computer's warranty here FREE
Feb 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
LAN problems with the router
Are you using the correct cable type. If it is a CAT5 type cable it could be you are using a patch cable rather than a straight through type or vise versa.
May 23, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
Computers & Internet Logo
1,420 people viewed this question
David Payne
David Payne
