Question about Motorola Mobility W375 Cellular Phone
Time set i need to now how to set the time on my phone.
  • Anonymous Nov 07, 2007
    how do i set the clock
  • 3 Answers
Here is a hint,
Turn off auto update or you wont see the time and date settings.
Posted on Jan 16, 2008
Go into 'Settings',choose 'Initial Setup',time and date are the first options shown.Perhaps you can tell me where I can find a proper manual for my W375?I bought a virgin one and all it came with was a foldout leaflet that's pretty useless.There must be a way to get rid of the virgin wallpaper,for example and to turn of the web browser permanently.It was possible on my old virgin nokia.Any help would be appreciated.
Posted on Oct 12, 2007
How do I set the time motorola vga 4x zoom
Hi Anonymous,
To set the time you need to go to Menu> Settings > Phone Settings > Time and Date.
Regards,
Gaby
Motorola Mobility
May 27, 2014 | Motorola Mobility MOTORIZR Z3 Cellular...
Incorrect time
model of phone would help, but some older phones you need to receive a call before it will update, some may have a setting in the control system setting for manualy setting time and selecting for day light saving..
most newer phone have a setting to set it auto or manually you will find this in the date & time location, also make sure you have selected the location for your time zone as well...sounds silly but see that to many time the phone is in the wrong zone and if not set to auto it will not update if you travel to current time zone and correct time
Mar 10, 2014 | Samsung Brightside
Need directions on how to set the year on phone
Press the Set/Save Button, Date/Time setting should appear after the first press, Press Set button again to enter the date/time. The year I believe should be first and blinking. Use the Up/Down key to change the year, then press "Set" then change or set the month, then the day.
Oct 27, 2013 | Innovage Touch-panel Phone 1502084
How to set time?
Normally in all phones as it is switched ON the time needs to be set before the main menu comes up. So as soon as the time window comes up you can set the time, time zone and proceed.
Also you can access time setting from the MENU>settings> clock/time/date set. Open the window and proceed.
Jun 15, 2011 | Cell Phones
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
How to set date and time in Samsung Corby 3650? Ihave recently purchased the phone but it is showing some other time and the date set is in 2009. Kindly help in this regard.
Go to settings---Date and time--->set your time and date and your time zone.And you can activate automatic update after that.So you no need to set the time again and again
Oct 14, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Uniden clock not keeping time, needs to be set
This model phone will not keep time. You can reset it, re-register it or WHATEVER. Next time the phone rings, it loses track of time again and has to be re-set.
Piece of junk
Mar 18, 2010 | Uniden DECT 6.0 Cordless Phone ID
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Time display
Check the network time settings. If the phone time is "Set by network" maybe the network time servers are messed up. Set the time on the phone manually and see if the problem is fixed. If the phone is already set manually see if setting it to Set by network will force it to keep correct time, but the internal clock should be more stable than that. You may need to get a replacement if these tricks don't work.
Nov 19, 2007 | Motorola Mobility RAZR V3
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
88 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
