Question about Canon imageRUNNER 1023N Black and White Copier
Canon ScanGear Ir - how to set defaults?
When I initiate a scan job from an app, Canon scangear Ir launches with a window to configure how the scan is done - flatbed vs. ADF, color/grayscale/B&W, paper size. The problem is that every scan job requires that I change each of the configurations. How can I set the default config for scangear, so that each time it launches, the settings are what I want? This is the Scangear Ir for Imagerunner copiers, not the the Scangear for USB desktop scanners. thanks!
  • 2 more comments
  • danielgcom Jun 15, 2008
    Nothing of much interest found when using regedit
  • Anonymous Apr 25, 2009
    i downloaded ScanGear CS and i install it so when i whana start it it does nothing i try to reinstall but nothing
  • Anonymous Mar 16, 2014
    Trying to set up scan to shared folder on windows 8 with canon IR 1025IF?
  • Anonymous Mar 22, 2014
    need to set the default paper tray
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Posted on Jan 26, 2008
I want you people to teach me how to install and to use a network scanner on canon IR2520.
Install the scanner driver (Canon Network ScanGear) found on the bundled CD. I assume you already assigned an IP address on your copier. Run the Network ScanGear software, the one you installed earlier. Click Discover or you can manually type the IP address of your copier. If your copier is discovered, click Test Connection. Remark is displayed that your scanner is ready to use. Click OK to save the settings.
Now, run 3rd party software (eg Photoshop). In File > Acquire > (Select Canon Network ScanGear). A window will pop up and you are ready for scanning. Note: If error "Scanner is offline" occurs, go to your copier and press Scan > Remote Scan > Online.
Jul 06, 2011 | Canon iR 2016i Black and White Copier
Got this imagerunner 2200 used and am trying to set it up to network scan, how or what do I need in order to do it?
for windows/Mac user:
instal driver on PC/Mac, instal Canon Network ScanGear software, setup ip to Canon iR2200. Run Canon Network ScanGear software, try to connect to copier. Use a software (adobe) to scan with the machine.
Nov 10, 2010 | Canon imageRUNNER 2200
Canon IR3300 Scanner
1) install Network ScanGear software from canon officiall site, search under ir 3300, and among all drivers there is scangear too.
2) when you install scangear, open it and press discover button, but the light scan on copier must be on, and set on ONLINE.
3) Then over eg. word2003 go to insert-pic.-from scaner or cam.-choose scangear- custom insert.
Jun 14, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Scanning question
The Machine must be connected to a network.Download Network Scangear software driver from the Canon webside,install it on your destop.After installation open the Scangear tool and select the discover button.The scangear will search for the machine on the network.As soon as it has discover the machine the ip address will show in the tool.Select the Machine and close the scangear tool.Select the scan button and set it to online.
Now you can scan in to a program like word or exel by Insert a picture from scanner.
Dec 14, 2009 | Canon imageRUNNER 5000 Copier
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from to and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Canon IR c3200 - CAn't dNetwork Scanning (Simple - Shared Folder)
Hi,ok you have to load the clolor network scangear exe file.If the scangear is installed,click on discoveron the color network scangear tool.It will detect the machine,select the machine.
Then it will be ready to scan into word or other programs.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 1023N Black and White Copier Logo
1,810 people viewed this question
old marine
old marine
