Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius WD62D
Sorry I know that this is for WD63 machines, but the door seal is split on my WD62D machine, and I wondered if you could tell me if it is a DIY job for a fairly profficient DIYer, or should I call an engineer? If it is a simple job, could you tell me where to get instructions from please? Many Thanks Milack
  • 64 Answers
Depends how 'proficeint' you are. Its a very fiddley job but can be done easily when you know how!! just have a go!
Posted on Oct 19, 2007
SOURCE:
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
How do i remove rubber seal on hotpoint washing machine for getting in to door lock
No need to remove seal.
Remove top cover, undo 2 screws securing door lock. and reach down inside the washer to access the door lock.. This is the easy to do it.
Feb 04, 2010 | Hotpoint Aquarius WD63 Front Load...
There is water leaking from the bottom of my machine. its not the drain pipe but can't find my manual to see where the filter is. could that be the problem many thanks Sue
Unlikely to be filter leaking.
Carefully check the door seal for a split or hole in it, it is easy to miss a hole, so examine it closely.
The filter is located inside the large black hose fastened to bottom of drum.
Hope this helps.
Jan 31, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Programing a wash without drying
I had the dial on the wrong setting sorry to be a pain
Julie
Dec 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
73 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
