Question about Logitech SoundMan X2 Computer Speakers
Logitech speaker problem
My computer has a built in sound card, however I have my Logitech SoundMan X2 connected to it but every time I play music there is no sound. So I tryed it on my other computer, it was the same deal. Then for some reason or other I connected it to a cassette tape player that had no sound, it came out as clear as rain. What is the problem with my Speakers?
  • 2 more comments
  • Bobov Sep 22, 2007
    It is hooked up but no sound is made by either ear or with headphones.
  • Anonymous Nov 08, 2007
    I have the same problem. My speakers worked when I first put them on for 2 days. Then the next time I start the computer the little green light comes on when I turn on the computer. Then it turns yellow and I can't hear the speakers. Any Ideas? Thanks
  • queendiva Dec 09, 2007
    my speakers are plugged up the green light is on the speakers but no sound is coming out.
  • vijaygupta89 Feb 13, 2009
    while statring green light of speaker turns on..but then within few seconds it turns off automatically...and im able to hear songs on headphones.....plzzzzz help me....
  • 363 Answers
Verify that the audio lead is connected to the correct line out on the computer. Check the sliders in the windows volume control are correct and mute is unticked. Try plugging some headphones into the computer to hear if the PC is actually producing an output.
Posted on Sep 22, 2007
the device comes with the drivers inbuild or in other media if still you are having the problem go the company home page and click on the supprt link
Apr 07, 2014 | Logitech SoundMan X2 Computer Speakers
Logitech soundman G1 cases don't function..Do I need a driver ?
Driver might need to be reinstalled but to confirm this you should attach any other set of speakers of Headphones. However the driver or improper installization of windows xp usually causes this on getting updated. I'm not sure that what windows you are using therefore you can probably just check if the cables are pind in right sockets and that the Speackers are getting power. As far drivers are concerned the Speakers do not have any drivers but the sound card does, therefore if you have not installed the drivers of sound card you may install them now. This may solve the problem hope fully
May 06, 2011 | Logitech SoundMan G1 Computer Speakers
Logitech Soundman S-20 speakers not working after Op Sys reload
Hi Aceofmktg,
go to start menu, control panel, sound. Then here go into the Tabs and select the Speakers. Apply, Done !
If it does not work, then I suggest you to contact the Logitech support for a replacement this is an hardware
failure and it's covered by warranty terms.
US/Canada support:
European support:
Jan 27, 2010 | Logitech SoundMan S-20 Computer Speakers
Speakers not working
Hi , have you installed your drivers for your soundcard you plugged the speakers into? if you have then it could be that the speakers are faulty and you would have to return them.
Dec 28, 2009 | Logitech SoundMan X2 Computer Speakers
Only two of my speakers work when i unplug them and place in different parts the actual speakers are fine--how do fix the problem
check all connections, the volume and the manual again. if problem persist and its still under warranty, use it
Oct 18, 2009 | Logitech SoundMan X2 Computer Speakers
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
Logitech speakers occasionally making loud thudding noise!?
i have the same problem.... its very annoying, i cant get it to go away!
Apr 19, 2009 | Logitech SoundMan Pro Computer Speakers
Problem hooking up Logitech X-530 Computer speakers to New computers.
you sound computer savy if you built your first computer. if you take a sound card pci and install it see if your speakers work ..most of time we assume because its new everyhing works. test and varify first. ...if you did not build your own computer return to store so you dont void your warrentee.
Nov 04, 2008 | Logitech X-530 Computer Speakers
Onboard Sound Problem
No you will run into alot of problems and you will destroy *********** board.My advice is that you get a different set of speakers that have a pin with suited size for your sound card.
the problem is that the pin of your current speakers is too long for the jack and as a result only contacts for one speaker are fully connected.
Your sound card has no problem,but if you realy want these speakers just buy another sound card and install it and hopefully it will work.
it is very risky
Mar 14, 2008 | Logitech SoundMan X2 Computer Speakers
Logitech SoundMan X2 Computer Speakers Logo
1,875 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
