Question about Vector 1000w Power Inverter
Low batt. light is remaining on. batt. good but no ac power
My battery died and put the charger on it but now the radio wont turn on and the lights and controls for the ac don't work?
Some cars..the module is affectd if batt ran low..below 12.6v they can be ruind. Test batt for holdn a charge. Same w alternator. Also the main cable from batt to alt cud b worn causing low flow
Jun 30, 2015 | 1994 Oldsmobile 88
Cruz tablet
The charging light should remain on as long as the charger is plugged in and charging I suggest you try to troubkeshoot your charger as it might be faulty.
Sep 23, 2013 | Velocity Micro Cruz T410 4GB 10"...
Rapid flashing battery light and battery apparently not charging- is battery dead or is charging circuit u/s?
Hello!
Tricky issue, try removing the batt, power it up using ac power, when booting try going to the BIOS page, try looking for the A/C adapter type. if ot shows there, then your good with your ac adapter, now try hooking the battery then check again in BIOS your battery status, is if its saying other than charging, then possibly its a battery issue, most batteries are good for 1-2 yrs, more than that batt hold will degrade. time to replace your battery...
Hope it help!
Apr 20, 2010 | Dell Inspiron 2200 Notebook
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Radio works on ac power but not on batt power
"Radio works on ac power but not on batt power AA batt seams to be ok" The AA battery is only for the radio memory and clock. Have you put a battery from your drill in the radio? if so check fuse inside radio.
Sep 13, 2009 | Dewalt DC011 AM/FM Radio
Charging problem 1991 volvo 240
14.6 means your voltage regulator or diode is suspect Despite having new alternator .Ive cross refrenced your smptoms in the haynes workshop manual and alternator is your only end answer.The haynes test is to start vehicle with multi meter connected across the battery terminals,increase the engine speed until the reading remains steady should be approximately 12 to 13v and no more than 14v.switch on as many accessories as possible(headlights heater blower radio etc)check that the alternator maintains the regulated voltage at around 13 to 14v.If the regulated voltage is not as stated then alternator is to be repaired/replaced.Good luck with it and a happy new year.
Dec 29, 2008 | 1991 Volvo 240
CPI Trouble Light will not Reset
Try to check the line if it is correctly installed to the proper area. maybe your battery doesnt have enough power to comply the proper amount of your system.
Dec 22, 2008 | Computers & Internet
Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
May 05, 2008 | Compaq tc1100 Tablet PC
Vector 1000w Power Inverter Logo
104 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
