Question about Garmin GVN 52 GPS Receiver
Hard reset gvn 52
It does recognize the maps as unloked, but i can't select the countries to find an adress... and i want to hard reset the unit but i don't know how,
thank you
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: How do I hard reset my gvn 52. Memory is full
Select tools then my data then clear all then you select yes.
Posted on Dec 31, 2009
Change the country setting for a garmin 1350
Typically, when the unit is turned on, the satellitetechnology is able to pin point the unit's current location and provide mapsbased on the user's position. However, if there is not a clear signal or youare located in a different country than the ending destination you are tryingto program into the unit, you may have to manually change the country. For thatplease follow these steps: 1. Touch anywhere on the display screen to access the mainmenu. 2. Tap or select the "Change Preferences" options. 3. Navigate to your map settings. In a Garmin this will belocated under the "View Maps" and then "Change Maps"settings. 4. Use the "Up" and "Down" arrows toscroll through the list of available countries. Once the country you arelooking for is highlighted, press the "OK" button. You will then beasked to select a state or more specific region in the selected country. Onceselected, press "OK" second time. Hope this will help you. Good Luck.
Aug 16, 2011 | Garmin Nuvi 660 GPS Receiver
My gps only covers Spain (the country I live in) Can I download driving instructions for the country of France ?
A GPS normally only comes with the map of the country it was purchased for.
You can normally 'buy' additional maps for other countries but you need to check that your specific GPS model has enough memory to handle the selected map for France (either whole country or specific regions only).
In any case, check with the dealer you got the GPS from and ask if any other EU countries maps came with your unit.
Hope it helps.
May 08, 2011 | Blaupunkt GPS
HAVING PURCHASED A LIMITED LIFETIME UPDATE FOR MY GARMIN NUVI 250W, I FIND THAT I CANNOT INSTALL WESTERN EUROPE MAPS. THE INFORMATION GIVEN WHEN I SELECT WESTERN EUROPE, IS THAT THERE IS INSUFFICIENT SPACE...
firstly the reason it cant see corresponding countries is that the garmin units treat each map as seperate , the only way to rectify it is to copy the maps folder from your device to your pc then delete the maps from your device and then download the western europe whole map, doing it this way will give you the space you require plus it will allow you to choose any of the countries in the map
Mar 28, 2011 | Garmin nuvi 250W GPS Receiver
I enter an adress and my garmin 1340 gives the not found message but the adress is on a conventional printed map. I do have sattelite recognition and I live in the south of France.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 03, 2010 | GPS
Says no adresses of maps found, what does that
Periodically, the firmware or 'brains' inside phones, mp3 players and GPS devices get confused. They begin to work erratically, or refuse to complete their startup routine at all. The good news is that 99% of the time, new life can be breathed into them by either a reset procedure or a firmware / system software replacement.
Here are the steps to fix your Garmin Nuvi 205W:
  1. If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
  2. Then I suggest a hard reset.
  3. Finally, replace the firmware and system software using webupdate.
I hope that helps.
Apr 12, 2010 | Garmin nuvi 205W GPS Receiver
Dec 31, 2009 | Garmin GVN 52 GPS Receiver
Missing links/buttons
press bottom right hand corner as soon as you turn it on and it will ask you if you want to reboot. you will get factory reboot
May 30, 2009 | Garmin NUVI 270 GPS Receiver
How to hard reset magellan 700
Hussam.. I believe the newest software upgrade you can get for the 700 is version 4.32 which is the same version used on the 760's. The maps are stored on the hard drive, so I do not think a reset will help but here is how it's done. 1. At the user select menu (first screen to appear after initial turn on) hold down the zoom out key (-) and the repeat button (on top of your unit). 2. Once at the "secret" menu, select reset user data. This will reset all of your personal information from the unit. All of your POI's will be deleted as well as your user name (which you can re-create of course) 3. Your unit will re-boot automatically and that's how you reset your unit. Like I said though, I do not think this will revive your maps. If you have the maps on a DVD-CD then you can reload them that way, otherwise send it to the Fort Worth, Tx repair center and they have the proper program to load data directly to the hard drive. Good luck! -Daniel
Jun 28, 2007 | Magellan RoadMate 700 GPS Receiver
Garmin GVN 52 GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
