Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
The picture is good but i noticed color sprinkle red and green
When im watching my plasma tv (LG 42 ") using cable or dvd player , i always noticed a tiny color sprinle of red and green on screen mostly on black back gound, but he picture is still good
  • Lito Tuazon Apr 24, 2009
    HELLO,
    tHANKS FOR THE REPLY,
    REGARDING THIS HIGH VOLTAGE THAT FEEDS THE PANEL, CAN I ADJUST THIS BY MYSELF? HOW?.
    ALSO THE X & y BOARDS THAT CREATING THE PROBLEM CAN I ADJUST THIS ALSO?
    THANKS IN ADVANCE
    REGARDS,
    LITO TUAZON
    New Friend:
  • 58 Answers
That could be a high voltage that feeds the panel, that can be adjusted (that voltage need to be verified first)
Also there is a couple of boards that may be creating the problem (X & Y main boards )
Posted on Apr 23, 2009
  • Marco M Apr 24, 2009
    you can adjust that but you need a multimeter to check for voltages and also this is a little risky because it handles kind of high so you have to be very careful.
    the voltajes are ussualy posted in the back of the panel
    look for Vsus, VA and VE.
I have an Insignia 42"
First, I would check the connection to see if everything is in it's proper place and plugged in nice and snug.
Second, I'd try watching something else on the TV and see how it looks, I'd also try watching something using the same cable/input the DVD player is using. If that fails, try a different cable.
If your TV checks out, and it's your DVD player, it might be time to upgrade to Blu-Ray or buy a new DVD player.
Hope this helps, cheers.
Kevin
Aug 27, 2011 | Insignia 42" LCD Flat-Panel HDTV
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Red in left sie of screen show up sometimes on 42 samsung SP P4251
What component(s) are you connected to this TV?And what type of A/V cables are you using?
Does it only happen when you watch cable or directv or dishnetwork?
solutiondoct
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
