Question about Hotpoint Aquarius WMA42 Front Load Washer
The conditioner will not be drawn into the machine
  • 56 Answers
Check if the conditioner valve is in around 3.4kohm,when machine is off and coil disconnected-use standard safety guidelines-hopr this helps
Posted on May 15, 2009
No cool air being drawn into house
check all circut breakers ALL.. might be fan not working ?
Jul 25, 2011 | Mastercool 67680 Evaporative Cooler Air...
Why does my a/c s compressor only run for a while then shuts down before it cools my apt
There is a sensor that reads the incoming air on the lower part of the air conditioner. One possibility is that the cold air exhaust is being drawn into the intake causing the sensor to think the room is already cold. Try pointing the air deflectors up and away to avoid the cold air from going right back into air intake.
Jun 09, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
My air conditioner has just stopped working with error code CH61 what does this mean?
Not enough air being drawn over the outside condenser unit. This could be for a number of reasons. The unit may be covered, restricted, or blocked. The condensor fan may be inoperable on the unit. Without a model number I would first check the outdoor fan for proper operation, and contactor and run capacitor. It sounds as though the compressor is coming on and going into thermal overload.
Feb 13, 2011 | LG Heating & Cooling
How many watts does a 59516-751 model require to run?
Answer
Simple Answer is just to know two formulas
Ohm's Law
V = IR
Power
P = IV
From those you can calculate voltage, amps, watts, ohms
V = Voltage (volts)
I = Current (amps or amperes)
R = Resistance (ohm's)
P = Power (watts)
Just solve for what you are missing.
Voltage times amps being drawn shows watts produced.
Watts divided by voltage shows amps being drawn or watts
divided by amperage shows voltage applied.
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
Do we need to use both hoses?
You could draw the air from inside however the system works much more effeciently with 2 hoses.
The air that is drawn into the unit and heated then exhausted back outside. If you don't use the second hose all the air that is exhausted will have to be drawn in around windows and doors or othe voids in the area. This would draw in warm moist air that would then have to be cooled and dehumidified.
Jul 19, 2010 | Danby DPAC120061 Portable Air Conditioner
How smoke affects air conditioners?
The smoke is drawn into the unit by the evaporator fan motor, & as the smoke travel through the filter & evaporator coil it leaves a sticky light brown residue, which causes filter & coil to get dirty quickly along with leaving a unpleasant smell.
Mar 02, 2010 | Heating & Cooling
Say ci intermitent in the display and sometimes stop cooling
The error code should be C1 and this would mean that the return air sensor is either disconnected or faulty. The sensor is clipped onto the fin plates of the evaporator where the air is drawn into the evap.
Oct 28, 2009 | LG Art Cool LA1000PR Air Conditioner
Too much power being drawn?
Get a amp meter and attach it to the incoming power and compare the 2 readings.Also the unit will have the run load amps on the name plate(RLA) they should not exceed that rating.
Aug 23, 2009 | Dometic Rooftop RV Air Conditioner
Gas emergency heat pump comes on with chemical odor
If the emergency heat doesn't come on very often, it will burn off debris that has collected on the heat exchanger causing the smell. Also, check that there aren't any chemicals that are being stored around the unit that would put out fumes that can be drawn into the system and when heated, cause the odor.
Mar 31, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Hotpoint Aquarius WMA42 Front Load Washer Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
