Cistern doesn't fill up, removed fluid master and the water just run very,very slowly.
valve is fully turn on. The supply pipe to the cistern are connected to tank in the attic. Is it possible that there could be an air lock in the pipes? or perhaps the gravity flow isn't good enough. Problem started with one toilet not filling up, now after 2 months the 2nd toilet stopped working. I checked the tank for any debris but looks clear to me.
Any solution?
Regards,
Darek
It sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Try checking the supply valve under the toilet some times if they are old the gaskets will get all chewed up and partially blosck your water from coming into the tank
Is the tank in the attic vented?
1 of the 4 air vents inside was frozen
I have an iphone 4s given to me and now Im trying to unlock the scree cause the person I got it from isn't around anymore
poor gas mileage...I changed spark plugs and air filter and still have bad mileage
the door latch spring has come off.. need to place spring in correct position
how do i open the Nokia Ovi Suite on my chromebook
