hi, my phone was working just perfect, but one day it got automatic switch off, i thought that the battery might be low, but it was fine, i turn it on, it was fine, but after few mins, it again got Off....
now this problem is getting common all day long.
i tried updating the software but it got Off in between the update process. what to do?
Had the same problem.It is a problem with the phone software.Need to format it.Will be done for no charge in any nearest nokia care showroom.Good luck.Please post comments and results.Also please do rate my solution.
I cannot access the web on my N76,How can I access it again?I use to access it but after several...
(More)
I cannot access the web on my N76,How can I access it again?I use to access it but after several times of using it all I have is an error message packet data not available.How do I fix this?
press call+*+3 this trick not working any other trick n76 Phone start-up failed. contact the...
(More)
press call+*+3 this trick not working any other trick n76 Phone start-up failed. contact the retailer
After a little digging around on the net, I managed to get back into the handset by doing pressing...
(More)
After a little digging around on the net, I managed to get back into the handset by doing pressing yes+*+3 while powering on the handset n76
