It won't update. I have never owned a psp before please do a step by step process on how to do it. When i try to scan the update it asks for a wpa key. What is this?
hi psp the net work is not working on the psp please send me a email the net work is a problem hi psp the net work is not working on the psp please send me a email the net work is a problem
AnonymousMay 06, 2009
I cant update itI cant update it
You can't post conmments that contain an email address.
It's
easy to update/upgrade the Playstation Portable (PSP) 3000 system
software to firmware version 6.20. There are two ways to do a PSP 6.20update
- regular file download and network update. We did an update on our
pink PSP 3000 using the network update procedure since our place has
wifi.
Why did we choose network update in
updating our PSP firmware to ver 6.20? It's much simpler. Here is a
quick tutorial on how to carry out PSP 6.20 update using Network Update
(Method 1):
Go to Network Settings to configure your PSP WLAN by setting up an access point.
Under Network Settings, it would be best to choose Automatic to
simplify the process. Your PSP console will search for any wireless
network available nearby.
To Update System Software to the latest 6.20 firmware version, Go
to Network Update. Be sure your battery is full because the update will
fail if you turn off you PSP console or if the unit shuts down due to
lack of battery power.
Method 2: Download File To Update PSP 6.20 Firmware Using a PC. If you prefer to update your console using the download method, here are the simple steps in doing this:
here is a step by step guide. If you still have problems or need further assistance please let me know and i will assist you further.
step 1
Your PSP will detect any wireless wireless network within its range as long as the wireless
adapter is switched on. The switch for this is on the left end of the PSP, near the analogue
thumbstick. If the switch is in the down position, the wireless network adapter is off; push the
switch into the up position and it'll turn it on. If you're not going to be using wireless
networking it's a good idea to keep it turned off as it'll make your batteries last longer.
step 2
When you turn on your PSP's wireless adapter it'll look for any wireless networks nearby. If
there's another PSP within range it'll automatically set up what's called an 'ad-hoc' network
between the two. This will enable you to play multiplayer games between the two PSPs with one
hosting the game and the other joining it. When you want to join an existing wireless network,
such as when you want to browse the internet, you'll be using an 'infrastructure' wireless
networking mode.
step 3
To connect to a wireless network, go to the home screen of your PSP and look under Settings. If
you scroll all the way to the bottom you'll find Network Settings, so enter this and on the next
screen you'll be asked to choose between Ad-Hoc and Infrastructure, so pick the latter by
selecting it and pressing X. Press O to return to the previous screen. You'll need to set up a
Connection. You can save the settings for 10 different Connections and you can choose between the
Connections you've set up whenever you need to use the Infrastructure network mode.
step 4
Pick New Connection and press X. You can give the new Connection a name by pressing X and using
the text-entry screen. Give it a descriptive name like 'Home Network' or 'University Network' so
you know when and where you can use it. When you've entered the name for your new Connection
you'll be asked whether you want to scan for WLAN settings or to enter them manually; select the
Scan option and press right on the directional-pad. Your PSP will then scan the area for any
available networks and collect the settings needed.
step 5
A list of available networks (called Access Points) will be displayed, giving its name (called an
SSID), whether it's encrypted or not and the signal strength. If there is more than one network,
use the D-pad to scroll down to the one you want to join and press X. You'll be asked to confirm
the settings so press right on the D-pad to scroll through each. When you get to the security
settings, choose the appropriate setting from the list, which is WEP in most cases, and press
right on the D-pad again. If you need to enter the WEP key, speak to whoever runs the wireless
network and they'll provide it for you. Press X and enter the WEP using the text-entry screen.
step 6
Once you've done that you can check the settings you've entered on the final screen and save
them. Now you'll be able to connect to the wireless network. If you return to the main home
screen you can now update your PSP's software by going to Settings and selecting Network Update.
Alternatively you can go to the Network section on the far right of the home screen to browse the
internet using the PSP's in-built internet browser. Or you can fire up that multi-player game
you've been itching to try out and get going!
Now you're online, if you need further assistance or get an error code please let me know and i
will be glad to assist you further. Thanks-Midwest-tek
try this guide. If this doesnt work let me know at what step you get an error and what the error code is. Then from there i can specifically diagnose your problem by providing you with step by step instructions on how to solve your error. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
first try this step by step guide. If this doesnt work let me know at what step you get an error and what the error code is. Then from there i can specifically diagnose your problem and give you a fix for the error code. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
Step 1
On the lower left-hand side of your PSP, you will notice a
little silver slider. Slide the switch up and this will turn on the WiFi
feature on the PSP. Of course, you do need a home WiFi setup for this
to work. Your battery also needs to be full. Even if your battery is low
and your unit is plugged in to an outlet, the firmware upgrade may not
work.
Step 2
With a fully charged device, go to your PSP's home screen and
choose "Network Update."
Step 3
This screen will ask you for your WLAN settings. Choose
"Scan" and let the PSP detect the network automatically. Choose the
right one and keep all of your settings in the default stage. Press the
"X" button and the PSP will save the configuration as your new access
profile.
Step 4
Choose it again and when your PSP connects to the network,
and if there is an update available, you will automaically see the
following message: "Network Update has found a later version. To
download, insert a Memory Stick with at least 14MB of free space and
press the X button."
Step 5
Press the "X" button and you should see the message:
"Downloading." IMPORTANT - Do not turn off your PSP or remove the memory
card during this time!
Step 6
When the download is finished, you will see the following
message: "Download completed. The update is now available on your Memory
Stick. To install now, press the x button. To install later, go to
[Game]." Press the "X" button to install the new firmware. You may see a
few other screens detailing new features to be included in the upgrade,
but eventually you will see "Installing."
Step 7
During the installation, again, do not turn it off or remove
the memory card. Once installation is finished, the PSP will tell you to
press "X" to restart the PSP. When it powers back up, the new firmware
will be in place.
first id like you to try this step by step guide. If this doesnt work let me know at what step you get an error and what the error code is. Then from there i can specifically diagnose your problem. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
here is a step by step guide. If this doesnt work let me know at what step you get an error and what the error code is. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
try this step by step guide and If this doesnt work let me know at what step you get an error and what the error code is. Then from there i can specifically diagnose your problem by providing you with step by step instructions on how to solve your error. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
ok try this step by step guide i can assist you with this. If this doesnt work let me know at what step you get an error and what the error code is. Then from there i can specifically diagnose your problem by providing you with step by step instructions on how to solve your error. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
try this guide. If this doesnt work let me know at what step you get an error and what the error code is. step 1
step 2
networking mode.
step 3
step 4
step 5
step 6
I cant update it
