Question about Cyberguard Computers & Internet
We have an SG-580, suddenly, when it was powered on in the morning, the green power light went off, and just then we discovered that the device has become very very hot even when power had been disconnected from it. Pls help
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
CompuGuy44
  • 432 Answers
SOURCE: Gateway monitors not powering on
Do you get an Amber light on either monitor?
Posted on Jun 22, 2007
SOURCE: no power
Disconnect your power. Remove the batter (CMOS), unlplug the power cable harness to motherboard. Plug in your main power cable cord (to power supply) then carefully plug the power cable harness to motherboard while simultaneously holding the power switch on computer down. Be sure sweaty palms are not touching the motherboard. power leads, or any other items as not to short any components.
Happy Computing!
Posted on Jun 03, 2009
  • 6 Answers
SOURCE: HP Mod a500n PC, flashing green ps light
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Posted on Jun 20, 2009
projdoc
  • 2237 Answers
SOURCE: Not getting power to a 580 smartboard.
if you have no led, the board has no power. you can only have 4 usbs in one hub, and each of those usb cables cannot be over 16 feet long. if it's red, it's not communicating with the computer. check the usb port on the computer. disconnect the usb fron the board and reconnect it. if it's amber, there is a checksum error, so reset the SC9 controller by pushing the reset button on the side of the SC9 for no longer than 3 seconds. if the pen tray leds cycle, all should be well.
Posted on Jul 17, 2009
I have an Acer predator G77600 running windows 7 it has been running fine until this morning I went to the PC and nothing was on the screen the pc was still turned on, I powered down and re booted but
When you turn on the power are there any sounds or lights coming? If not It sounds like a power supply problem, which is quite common. You need to get a tech to check its outputs. A replacement one is not too expensive and fairly simple to fit, but you need advice to get a quality one
Mar 28, 2014 | Acer Predator G7760 Desktop Pc Intel Core...
Speakers suddenly dead?
Investigate the "no green light" condition -- did some animal chew through the power-cord? Did some child pull the power-cord out from the outlet? Did your room-mate go on an "energy-conservation" binge, and turn the speakers off?
May 29, 2010 | Audio Players & Recorders
32" Dynex No Power, Power on/off light will not light up
Check the power supply module first for blown fuse, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 12, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
No power - suddenly went dead, no green or orange power light.There is mains power at the monitor's power input socket.
Check all caps in power supply. Look for the tops of the caps to bulge. Replace any that looks or smell bad, like a sulfur smell. Make sure you put them in the right way. I usually increase a cap that blows. If its a 16v I go to a 25v or a 25v to 35v. keeping the same ufd. Because of the surge, off and on, It helps.
Oct 26, 2009 | ViewSonic VX924 19" LCD Monitor
Acer 5920 -The power suddenly went off.
Probably this is due to surge current happend in the circute, butter not to switch on your lap. consult the service centre. Its is better not use the same adaptor for more troble shooting.
Oct 13, 2009 | Acer Aspire 5920-6727 Notebook
PS3 with no Power?
it might be the wall plug try a different one
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Computers & Internet Logo
52 people viewed this question
Top Cyberguard Computers & Internet Experts
David Payne
David Payne
Are you a Cyberguard Computer and Internet Expert? Answer questions, earn points and help others
