Question about Tyan Tomcat K8E Motherboard
OS installation problems
Hi i am trying to build a file server with these specification: Tyan s2865 MB Amd 64 3800 processor 2 GB Crucial ddr 400Mhz ECC 2 500 Gb Sata drives and of course a floppy drive and a dvd drive. my problem is that i cannot install any Win based OS, what happens is that after the normal boot, the win installation ( i have tried the win 2003 server which i need, and then also the XP to see if it would have worked)the win installation stops as soon as it is starting to copy the files on the Hdd. It reboots and the problem comes back everytime i try to install any OS win based. Any suggestion?
    Sergeant:
    Champion:
  • 293 Answers
Hi, hi check your power supply, hard disks, cd drive, and memory FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 22, 2007
Need scsi/raid drivers on floppy to install winxp pro (at f6 prompt)
Hello the drivers can be downloaded here:
http://www.tyan.com/support_download_drivers.aspx?model=S.S2865
You need to unzip the file before you install the driver.
It should not be nessesary to install drivers before installing the windows system.
Check your bios boot settings to boot from the cdrom or dvd drive.
The cd or dvd drive must be the first boot device in order to boot from the windows disk.
Install windows with only one harddrive.
You can also add a harddrive later, when the installation is done and all drivers is installed.
Good luck
Jun 20, 2013 | Tyan Tomcat K8E Motherboard
My wife's computer is an Acer Aspire 5100 with a 4000 AMD Athlone 64 processor. It came with only 1 GB of memory and is runniing Vista Home Basic. It is terribly slow and I would like to increase the...
yes one will be for single channel ram the other for daul channel ram.if you have the acer owners manual it will tell witch ones are single and witch one is daul.
Sep 21, 2010 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
I need to get more ram. can't seem to find my product # sr1920nx. can you tell me what is compatible to that
Here is what you asked for from memorystock.com
Presario SR1920NX Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 4.0 GB Memory Expansion 4 sockets Memory Comments PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. CPU Type 2.2GHz AMD Athlon 64 3500+ Model Comments GeForce 6150 LE ChipsetI recommend Crucial brand memory. Hope this helps:)
Aug 22, 2010 | Computers & Internet
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Black screen and three beeps
your m/boar is now not supporting the ddr which you are putting in, so you have to replace your ddr with Kingston DDR it'll solve the problem
Dec 06, 2008 | ASUS K8V-MX Motherboard
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Dell 733 memory
goto http://www.crucial.com/ and run their memory checker. it will tell you what can be put in your system. They are very competitively priced.
Nov 23, 2008 | Computers & Internet
Cannot install any Windows OS system
My first course of action would be to isolate the problem. So what i would do is un hook one of the 500 gb Sata drives. Then try to install on one. Once you get it up and running hook the second one up and let windows find it. Also another note of thumb is make sure you have not over exceeded your ram slot capabilities. Find the techical manual on the manufactures web site. Each ram slot has a max amount and speed. If you exceed these it can cause windows programs to halt. I do think that if you isolate down to one sata drive install your os then add your second Sata you should be good to go. If you are still having problems feel free to contact me. TechWizard
Sep 21, 2007 | Tyan Tomcat K8E Motherboard
Tyan Tomcat K8E Motherboard Logo
297 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Andrew Taylor
Andrew Taylor
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
