Question about Sharp AR-M237 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
  • Sharp Expert
  • 257 Answers
H3 means abnormal high temperature. Check the thermistor if its shorting or is worn-out or heat roller worn-out.After repair then clear with command 14.
Posted on Oct 31, 2009
I have aproblem with sharp ar-336?
the code is u2-11
Posted on Oct 16, 2009
    Sniper:
  • 67 Answers
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Posted on Apr 21, 2009
3 Suggested Answers
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
I have a Sharp AR-336 that's showing me F1-00 error code. What is this and how do I fix it?
F1-00 is a communication error between the copier and the finisher. It could be a loose connection (wire that connects finisher to copier) or it could be worse like a failed board. It could be the finisher board or the PCU board on the copier.
Make sure the finisher cord is firmly connected to the copier.
Make sure the copier is not plugged into the same wall outlet as another piece of equipment that might be drawing excessive power. do not plug into a cheap surge protector with other items.
If problem persists call a tech.
Hope this helps
Apr 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR-336 with an error code of E7-11. How do I turn this error message off?
The E7 can not be "turned off". This error usually indicates a bad laser unit or "shading" problems. You could try cleaning all the glass/mirror components including the white shading strip under the glass - it may help.
Probably need a new laser.
Mar 19, 2009 | Sharp Office Equipment & Supplies
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Copier Logo
506 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
