Question about Samsung ML 1610 Laser Printer
Samsung laser ml1610 after replacing the toner, does not print
Does not print correctly, i have cleaned it, bought a refilled cartridge, but does not print well.
    Champion:
  • 214 Answers
Suspect remanufactured toner cartrige Inkypete
Posted on Apr 21, 2009
I refilled my toner ml 2010 when i print the right side of the page is very light hardley any ink
You need to clean the ink cartridge. Check for software on you computer under programs. You could also put some rubbing alcholol on a parer towel and lightly rub the print heads clean.
Jun 15, 2011 | Samsung ML 2010 Laser Printer
Hello, I own a Samsung Laser Printer SCX-4600. The initial toner is about to get finish. I am not sure whether to go for a replacement or to just refill the toner. Its the first time.
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 20, 2011 | Samsung SCX 4600 multifunction Laser...
I am using samsung ml-2245 when refill the toner it is acccept the toner
Perhaps you'll need to replace its lockout chip. Toner cartridges have a page counter and that needs to be reset after the cartridge has been refilled. Printing won't commence when the lockout chip has not be replaced with a compatible reset chip.
Nov 14, 2009 | Samsung ML-2240 Laser Printer
Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 26, 2009 | Samsung ML 2010 Laser Printer
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
Sep 05, 2009 | Samsung ML 2010 Laser Printer
Samsung ml1610 gives faint print. (even self print) is this because of drum or blade or toner powder?
Try checking out your toner cartridge on other printer or another toner cart on your printer if you get the print fine on your printer then your toner is troubling or else the mainboard of your printer is problem which is not allowing proper flow of toner on paper.
Sep 02, 2009 | Samsung ML 1610 Laser Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Printed document has light spot running down entire page
Hi, On another Samsung model (ML1610), I tried shaking the toner cartridge left & right (presumably to evenly distribute the powder inside). On another instance, it was caused by a replacement cartridge (not original) and then again was when I tried simply refilling the old original cartridge. In all cases, the drum (which was inside the cartridge assembly)had to be cleaned, or the cartridge replaced (with original). The most tedious was when I had to open the cartridge and remove the replacement toner that has formed into solid lumps. Hope this be of some help. Pls post again how things turn up. Good luck and kind regards.
Jul 30, 2007 | Samsung CLP 300 Laser Printer
Samsung ML 1610 Laser Printer Logo
170 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
