Question about HP Compaq Presario R4000 Notebook
Playing DVD's I am having a problem playing DVD's on my laptop. This problem just started. They play choppy and do not read correctly. My videos that are on my computer play fine, its the DVD's that don't work. What is my problem?
  • mathz19 Sep 22, 2007
    No that didn't help. I was wondering if I had to uninstall and then re-install the DVD drive. Would that put the settings back to normal, and how would I do that?
  • Ichiban907 Mar 08, 2008
    Same as above.
    THERE IS A WAY TO FIX IT.
    It has happened to me before.
    Something to do in Device Manager.
    Unfortunately, that knowledeg has gone, well, up in smoke.
    Sergeant:
  • 457 Answers
Have you checked to see if your drive isnt too full. This can be the problem why it has only just started. I bet if you got rid of some of your films in that machine watching a DVD from the ROM would be a pleasure. I know my sister has that problem and refuses to part with her films so she has to watch here DVD on another machine because she too has to many videos in her laptop. The poor machine and CPU is working overdrive and the RAMS too.
Posted on Sep 21, 2007
  • Anonymous Sep 22, 2007
    welll the only way to install a DVDROM/Drive is to unplug it. Your not having a hardware problem your having a software problem believe me theres is no software to run your DVD drive NONE. The only software that the drive uses is the DVD player change it put another player in its place I bet you still have the same problem. You said yourself the videos in your machine plays ok but when you put a DVD in, its choppy....please its logical. Thats all I have to say in the matter. Unless someone out there has a better solution which I doubt. If you take it to get fix up (so to speak) in the repair shop they will tell you the same.
SOURCE:
Sony VAIO vgatz750p has problems plating video. Playback is in almost slow motion and choppy
You probably need more ram memory. Also try playing a video in your dvd player. If it plays slow and choppy you definitely need more ram memory.
If you are trying to play a video from a website (streaming) then three things can affect how smooth it plays.
1) Memory - your ram memory might be low
2) The website might be experience heavy traffic from many users.
3) The Line Speed of your internet connection from your service provider might be slow. For example: AT&T sells about 3 or 4 different packages and each one increases the line speed for uploading or downloading. If you buy the low end package the line speed is very slow on uploading and downloading or streaming. It's ok for just surfing, but nothing else.
May 05, 2012 | Sony Computers & Internet
Computer
Choppy Video? What do you mean choppy video? Is the video starting and stopping rather than playing continuous? If so, either you need more memory or the site you are watching the video from is slow. Also sometimes you line speed on the computer might be slow if you are watching the video online.
How does the video play if you played a DvD in your computer? If it plays the DvD without stalling, then your problem is more than like the site you are watching or the line speed as you stream the video.
Mar 29, 2012 | Computers & Internet
When I play a movie the picture and sound gets "choppy" even with NEW dvds
You can try using another media player.If that does'nt work ,your DVD drive may be bad or need cleaning.Sometimes a bad ram chip can cause the video to mess up.Try playing a movie directly from your HDD downloaded from a website and see if its choppy if its not then its your DVD drive.If it is still choppy it could be the media player your using or it does'nt have enough ram memory/virtual memory.If you have XP change your virtual memory settings and the refresh rate in task manager.(Bring up task manager,go to view tab then update speed to HIGH).
Aug 11, 2009 | HP Pavilion zv6131us Notebook
DVDs Choppy playback
its not a error, your computer is just slow, try using vlc media player to play a dvd and tell me if it plays better
Jun 14, 2009 | Compaq Presario R3000 Notebook
E-System laptop with slow dvd playback
This can be a bit of a tricky one to figure out. My initial response would be that you have another program or process that is causing your computer to play 'choppy' video. When you have a newer computer that was recently working just fine and now all of the sudden the video is choppy, it is usually due to another process using CPU cycles that are so important to video playback.
Start playing a DVD, but don't go to full-screen mode. Open the Task Manager. Right-Click on the task bar and select Task Manager. Click on the 'Processes' tab. There is a column labeled CPU, click on the heading 'CPU' twice. This will order the processes in order from highest CPU usage to lowest. The top two processes will most likely be your DVD player and the process that is causing your choppy playback.If the offending process isn't essential (i.e. anti-virus), then click on said process and then click the "End Process" button.
Hope this helps.
Mar 09, 2009 | Computers & Internet
Philips dvd ram sdvd8821 does not play
this the most costly part of the drive, better to get a new drive with warrenty
Oct 19, 2008 | Acer Aspire 5100 Notebook
My xbox 360 is not playing my games. it said to clean it and re-start the game. i then put several other games, new and old it didn't read them either. i disconnected the cables, i let it cool off, but it...
When this starts happening, it appears that you have a problem with the DVD player. You could try to buy a DVD lens cleaner (it looks like a CD with a little brush on it), but I suspect you may ahve to take it to an authorised service technician to get the DVD unit replaced.
Apr 14, 2008 | Video Game Consoles & Games
Dvd playback freezes or is choppy
Get a cleaning disk and run it through the machine. Could be a dirty lens on the laser.
Jan 22, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
Dvd choppy
Well try the following steps:
  1. reinstall the video driver from the support site.
  2. remove the primery and secondry channels from the device manager and than restart the system.
  3. remove the drivers for the dvd drive from the device manager as well and restart the system
  4. try playing with different softwares.
Dec 26, 2007 | Computers & Internet
DVD playback is warbling
Have you tried viewing in a different software, as i found that acer use a form of Power DVD as their standard movie player which comes installed with the system. Try viewing in media player for example.
Jan 12, 2007 | Acer Ferrari 4005WLMi Notebook
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
