Question about HTC Touch P3452 Smartphone
BATTERY CHARGING after charging my HTC P3452 within couple of minutes the battery goes low or shuts up completely
  • 1 more comment
  • ashu1947 Apr 23, 2009
    I am trying some more things, like charging thru USB, which is working fine for the moment. Let me see till monday and try the charger on weekend and see if the same problem persists
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    have checked the solution or not pls let me know abt it
  • Shoaib Rais
    pls try this
    hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
    if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
    otherwise change ur battery and pls tell me if it helped
Use hibernate mode for standby
Posted on Apr 30, 2009
Am charging my mobile but when i keep it in the mobile it is showing that the battery is low or empty
Many cell phone used for a long time will met this kind of problems, it seems full charged, but once you are calling someone, the battery power will show empty.
1, mobile phone motherboard leakage lead the current too large.
2, the battery itself is aging.
Try to find out the problems and maybe an external battery can help you a lot
Apr 03, 2013 | HTC Touch P3452 Smartphone
HTC evo went dead. Battery does not seem to charge when plugged in and does not start. Removing battery and insterting did not help. Cant do a reset since the thing will not start
Mine did the same thing I think the protection on the phone to shut it off when it reaches low lvl did not work I had to put my battery in my hero to get it recharged so there must be a flaw with the phone charging a completely dead battery maybe it has to have enough juice to know it has a battery in it ......
Apr 21, 2011 | HTC EVO 4G Smartphone
Upon startup engine idles rough then speeds up and returns to normal idle .After a couple of minutes the volt light comes on then no power then a complete shut down.Starts back up for a while then shuts...
OK, the volt light means that the alternator is not charging the battery. It could mean the battery is shorted out, or the battery is bad or low on charge due to an alternator not charging.
Replace the Alternator and battery as indicated by standard voltage output tests under load.
The computer in the car will not operate the engine properly on low voltage.
Fixing the charging system, may resolve the rough idle (meaning that it may be trying to relearn after data was erased by low voltage of the battery), and the speed up.
Try the charging system first, and once that is repaired, reevaluate the engine driveability and speed and idle smoothness, after it relearns.
Good luck on this repair.
Nov 06, 2010 | 1999 Buick LeSabre
I am not able to charge my cell phone HTC P3452
Hi
If you are not able to charge your cellphone, there are several factors why:
  1. your charger connector is defective
  2. your charger terminal is defective
  3. your battery is defective
To solve this, you can check your charger connector with multitester, if it's working or not. If you test it and there's a movement, then the charger is OK. Next, check the charger terminal, using multitester. If there's a movement, then it's OK. and you'll know that the problem is on the battery.
May 25, 2010 | HTC Touch P3452 Smartphone
Fully charged mobile battery goes dry within few hours(3 hours)
If it is 8 Mths. old, it should be under warranty.Have the providwer fix the issue.
you can try Kaiser Tweaks:
http://www.jongma.org/KaiserTweak/
***Copied from this link:
http://www.htcwiki.com/thread/935379/Battery+Life
which will change the settings in the registry automatically:
These WILL work, and WILL improve your performance!
1. HKLM\Comm\AsyncMac1\Parms\DisablePowerManagement
Change Dword value from 1 (default) to 0
2. HKLMComm\Irsir1\Parms\DisablePowerManagement
3. HKLM\Comm\PPTP1\Parms\DisablePowerManagement
4. HKLM\Comm\L2TP1\Parms\DisablePowerManagement
To make these registry changes, I used CeRegEditor. Works from the computer and connects to the phone/PPC while synched. I have noticed an improvement in battery life. Should work with WM5 and WM6.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 15, 2009 | HTC Touch P3452 Smartphone
Battery go dry automatically when we remove the charger,,
I am facing similar problem, i use USB charging then it works fine else the elctric charger is pretty useless
Jun 09, 2009 | HTC Touch P3452 Smartphone
Charging Problem
Sounds like the circuitry that controls the charging of the battery has gotten damaged. You can try using regular non-rechargeable batteries if the camera can use them. Otherwise you will have to find another way to charge the batterys, if you can find an external charger for the batteries that should work too. Hope this helps.
Aug 26, 2007 | Panasonic Lumix DMC-F7 Digital Camera
HTC Touch P3452 Smartphone Logo
132 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
