Question about Garden
Where does small spring fit in gun of karcher pressure washer kb4040
  • Anonymous Mar 25, 2014
    how to put spring back gun
  • Anonymous Mar 31, 2014
    looking for a patio cleaner to fit champion 1800 power washer
    Problem Solver:
  • 10 Answers
Most Karcher guns I have worked on have had a spring behind valve between hose pipe inside gun.
Posted on Apr 22, 2009
Will a T50 patio washer connector pipe, fit to a karcher 111A pressure washer gun?
Some gun and wand pieces may be interchangeable among different brands. Like lawn mowers, even though there are quite a few different brands/labels, they are made in the same factory.
Apr 10, 2015 | Karcher Garden
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 | Garden
Karcher KB4040 pulsing when trigger closed and has lost about 50% of its power
Just google " stripping down Karcher KB4040" A YOU TUBE CLIP will show you hiw to fix it and what tools you need
Jun 05, 2012 | Garden
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
Trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
Aug 03, 2009 | Karcher K2.26 Electric Power Washer
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Karcher power washer electric K3.97 gun has two springs can not find where one goes.
have a look on karcher web site
www.karcher.com
click on europe
then click in international
go to service then spare parts
put in k3.97 and have a look.
hope that will help
damian
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
325 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
