Question about Toshiba 1370 Black and White Copier
My paper keeps "kinking"
Paper goes in ok but then suddenly after the copy it has a fold in the upper right hand corner. It's not folded over just wrinkled over and the image is messed up at that location. We have cleaned but to no avail..Any tips?
  • mdavisdc Sep 22, 2007
    dont know what any of those things are even though mechanncally savy
  • 24 Answers
Check the fusing unit.Pressure roller,pressure roller bushings, thermistors for over heating,fuser roller. replace if defective.
Posted on Sep 22, 2007
After several copies the paper gets very warm and paper rolls on the edge and jams
Rolls on the edge meaning it curls upward or folds a corner? You might try pullig out the paper cassette (tray), removing the entire contents and flip upside down (face down) this should help to alievate paper curl. If it is folding corners, you may need to have serviced. Let me know, please.
Oct 09, 2009 | Canon PC-1080F Plain Paper Laser Fax
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
Envelopes are getting wrinkled when run through the Brother DCP 9040CN. How can I prevent them?
Unfortunately when feeding envelopes it is quite common for them to wrinkle a little simply because of the way envelopes are folded. The paper is thicker in certain areas because of the folded paper and the glue that holds the envelope together. You could try different brands of envelopes some don't wrinkle as bad as others but in my 37 plus years of working on copiers and printers I have never seen any envelopes that won't wrinkle a little, you may just have to live with it.
Aug 19, 2009 | Office Equipment & Supplies
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Corners folding while copying
if it is just folding the paper back without pressing it, then its a problem in the fuser. Paper sticking to long to the upper fuser roller and catching either a pick off finger or a mylar on the exit of the fuser.
Hope that helps...
Jun 17, 2008 | Ricoh Aficio 1035 Copier
Hp lazer 1300
The Printer's Fixing Film on the fuser assy is broken. It should be replaced. Go to a Service Center and replace the fault part.
Mar 05, 2008 | HP LaserJet 1300 Printer
Toshiba 1370 Black and White Copier Logo
98 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
