Volume turn up
Hi I have a HM HS200 Suddenly it starts to turn the volume up, all by itself ??? What to do.. Ole
    Brigadier General:
  • 8,546 Answers
Let's eliminate ghosts and goblins. I can't identify your unit. Give me a make and model number, maybe a noun like "receiver'. For example, do you mean Harman-Kardon HS 200?
As a test, locate the remote control window on the front of the unit, if it has one. Set it up to watch or listen to something then cover the remote window on the unit with a small piec of cardboard. If you can't locate it's infrared receiver for the remote just cover the entire front of the unit with something sufficiently opaque to block your remote. Try it to be sure the unit can't see it.
If the expected problem never comes back you have a stray signal from something else in the environment getting interpreted as a 'volume up' command. Then look around for other remotes being used, wireless devices, use your imagination. I used to have a remote-controlled space heater and my TV would sometimes shut off if I used the remote. Does the unit have line-of-sight to a nearby house? Maybe something next door (garage opener?) is interfering.
If it still happens and there are no other infra-red devices nearby you have a ghost.
Posted on Apr 21, 2009
  • David Dunn
    David Dunn Apr 27, 2009
    Can you tell me if you fixed the problem - what was it?
Why projector lamp does not function anymore but blower and other butons ok. Is there a resetter for its lifespan?
nope !! hence the lifespan of a light bulb , but good news !! the light bulbs are replaceable !!
Dec 03, 2015 | LG Hs200 Projector
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Razer Chimaera 5.1 Headset turns volume down until mute by itself
Did you ever get a reply for this? I have the same issue. Sometime I'll replace the batteries or recharge it and it works great for a little while then suddenly starts auto turning the volume down...
May 05, 2012 | Razer Radio Communications
It suddenly stop working
hm,hm the contact the battery has is that OK?
kolbrun
Feb 24, 2012 | Cerruti Genova Swiss Leather...
The volume goes up by itself - SABA M5115GT
This is due to the signal reception. Some channels are broad casted with strong signal strength. Therefor you will find the audio is louder than other channels. Also, if there is voltage fluctuation/surges/spikes that is also responsible for suddenly increasing the volume. Best is to put a voltage stablizer
Jan 22, 2010 | Televison & Video
My Kenwood DPX-4020 suddenly turns up to max vol
you probably have a bad switch. you need to use a multimeter and check the resistance of your volume up switch, if less than a few meg., the switch is bad.
Oct 05, 2009 | Kenwood DPX-4020 CD / Cassette Player
My handset ringers are ''off''. How do I turn them on again? Uniden TRU4985
Hi there try this,
When the phone is in the standby mode, press menu/mute.
2) Press select/ch.
3) Press + or - to move the pointer through the ringer
settings (Ringer Off, Ringer Low, or Ringer High).
You will hear a ringer or melody at the selected volume.
4) Press select/ch, you will hear a confirmation tone.
Ringer Mute (temporarily)
You can temporarily mute the ringer tone. When the handset is off the base and the
phone is ringing, press end. The ringer tone will return to the previous setting starting
with the next incoming call.
[ 20 ] BASICS
• If you select “Ringer
Off”, “Ringer Off”
appears on the display
when you make or
receive calls, or
charge the handset.
Ringer Volume Setup
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Ringer Tones”, then
press select/ch.
You can choose from 6 ringers or 4 melodies:
- Ringer [Flicker, Clatter, Leap Frog, Ping Ball, Reminder,
Soft Alert]
- Melodies [Beethovens9, For Elise (Elise), Merry Christmas
(Merry-Xmas), Home Sweet Home (Hm Swt Hm)]
3) Press + or - to move the pointer. You will hear the ringer or
the melody as you scroll through the options.
4) Press select/ch and you will hear a confirmation tone.
Ringer Tone Setting
• If
Sep 27, 2009 | Lands Phones
138 people viewed this question
 Grubhead
Grubhead
