Question about Samsung SYNC SGH-A707 Cellular Phone
My cellphone is a Pantech TX-215C, if i close the phone or put even a tiny bit of pressure on the back, like just holding it and the phone turns off, sometimes it does it for no reason. what is wrong with it?
    Sergeant:
  • 274 Answers
Battery connection
Posted on Apr 27, 2009
I need my pantech networ pin
You can get network pin for Pantech Crossover (P8000) from the online vendor MobileUnlockSolutions.com .To get the service you need to submit your mobile model,country name,network provider name and IMEI number.
Nov 24, 2013 | Pantech Crossover (P8000)
LG vx8350r hinge is broken on right side. Should I look for repair parts or a replacement phone? My wife like a simple phone and would keep this model if I can get it fixed
My VX8350 broke on the right side too. Actually it cracked and the pieces, 2 if I remember correctly, kind of were just hanging there (in other words I did not loose any pieces of plastic). I did a very careful repair and it has held now for about 1.5 years with no problems and I've even dropped the phone about 4 times or more since the repair.
I used the CA glue, (cyanoacrylate glue or some know it as instant glue). But be careful so you do not glue your hands to the phone. Use VERY LITTLE glue cause it WILL wick into places you do not want it to go. Lastly, you have to index the metal piece in the hinge (use a hefty pair of tweezers) before gluing so the spring with work correctly and hold the phone either open or closed. If you error on the indexing, try to error on the side which will keep your phone tightly closed when closed and just barely short of fully open when open. That way you won't be catching the closed phone on things with it hanging partially open. It doesn' t cause any problems being just a tiny bit short of fully open.
So, open the phone, carefully tilt the two halves to expose the metal hinge, index the hinge, carefully rotate the two halves back to their proper position and carefully test the opening and closing action. If it's good, or good enough, then put the chunk(s) that broke loose back into position and while holding everything in place put a TINY bit of CA on one of the cracks. This should setup very quickly (hence the name instant glue) and if you can still remove your finger from the phone, do so, and put a tiny bit of CA on any other areas or other cracks where the glue did not wick to. Remember to use very little glue for this or you'll be sorry and your phone won't work. If you did this properly, your phone will now open and close like it did before...or very close to it. Good luck.
Aug 16, 2011 | LG VX8350 Cellular Phone
How do I turn the ringer back on my Samsung phone. It is now on silent and I cannot get it back on. Tx!!
Ok try this long press hold the number sign in your cellphone keypad see the silent icon will change or if this doesn't work go to settings then go to profiles or user profiles then choose a different profiles. Hope it will help you
Jul 22, 2011 | Samsung Smooth SCH-u350 Cell Phone
The touchscreen on my pantech pursuit isnt working! Have tried charging the phone, turning it off for long period of time then turning it back on. taking out the batter and putting it back in. Nothing is...
sir the touching sensor of your cellphone has been failed give to the related service center for servicing the touching sensor device [or] the will change the new touching sensor device to solve the problem.............
Nov 24, 2010 | AT&T Cell Phones
My pantech matrix was working fine but it said that my battery power was low and 3 seconds later it died then when i put my second battery in and turned it on the screen was white so i turned it off and...
Many users of the Pantech phones have been experiencing the same thing. There are a lot of default in this phone. I would suggest you to return it to Pantech and try to get a software upgrade (if there is!). Although, I would recommend you NOT to use it. Even if the Pantech exchange it for a new one, the same problem will happened in a day or two.
Jan 04, 2010 | Pantech Matrix Cell Phone
"Smartchip not provisioned MM # 2" What does this mean???
Your smartchip apparently isn't active with your cellphone service company. Are you certain that the chip you have installed in the phone is the one that your cell service gave you currently? You mentioned putting minutes on your phone, so I'm assuming you have a pre-paid plan. You must have a smartchip that's specifically set up for that type of service.
Nov 14, 2009 | Pantech Matrix Cell Phone
My pantech matrix by at&t, when I slide it to the side and it shows my keyboard it won't stay up. Also when its just resting and the phone is closed it doesn't stay closed it will slide open to the...
Screws usually come out that hold the springs 95% of the time is most likely the problem. So if you have the screws and the springs you could put back together. Otherwise you can send to us or take to local shop for the repair. www.cellphonerepairinc.com 972-931-8601
Nov 11, 2009 | Pantech Matrix Cell Phone
I put a password on my pantech duo and i forgot it!!
This worked for me....
press and hold down the S and the L keys while powering up the phone. Continue to hold the S and L keys after it turns on. It took about a minute of holding the two keys down, but it worked. It did wipe everything I had on there off. Including the lifetime call timer!
Jan 04, 2009 | Pantech PG-3600 Cellular Phone
Pantech c150 will not turn on
Hold the power button down. My wife's took almost 30 seconds to power on.
Feb 06, 2008 | Pantech C120 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
103 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
