Dell inspiron 1300 won't reboot. HELP!!!
Start Dell Inspiron 1300 then on screen reads "No bootable devices--strike F1 to retry boot, F2 for setup utility. Read failure on internal hard drive. Recovered once by F12and then diagnostics but nothing since. Please help, this is my old faithful. Many thanks, Dave.
    Sniper:
  • 50 Answers
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Posted on Apr 21, 2009
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
No Bootable Devices
Hard drive is toast
You will have to change it out and reload the "OS"
Feb 13, 2010 | VIA Bootable IDE Compact Flash Reader for...
Turn on Inspiron 1300 and get 'No bootable devices-strike F1 to retry boot. F2 for setup. Tried F1 no help
First off, if you have a floppy disk drive, make certain that there is no disk in the drive. If not, then do the same for a CD or DVD drive. Make sure they are also empty.
If all are empty, and you still get this message, then it is a safe bet that your hard disk has failed. It is possible that the disk controller failed, though, so if you can find a way to try that hard disk in a different computer, do so. If it works, then it is your disk controller, and that is usually on the motherboard.
But you can buy a disk controller that will fit into an expansion slot on the mother board, and allow you to override the original one. That being said, follow all instructions, and see if you can then get the computer to boot with the original hard disk.
Good luck,
-a.
Nov 23, 2009 | Dell Inspiron 1300 Notebook
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
My dell inspiron b130. says no bootable devices and strike f1 to retry boot. f2 for setup utility. but nothing happens just repeats sentence over and over
It may be that your hard disk is shot - or its connectors may have come loose or slightly corroded. Remove the hard disk and then reseat it back again. Good luck.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Can't System Restrore Dell Inspiron 531.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
