Question about Ovens
How to operate oven
Hi , I am new to UK and I dont know how to operate an oven. Can you let me know the basics of operating an oven. Oven Model :Zanussi FM 5230 Convection
  • Anonymous Nov 01, 2008
    While trying to bake I can't figure out what the symbols mean on the oven knob. Its got a lightbulb a fan, a fan and some spikes, spikes alone and an equal sign. Help?
2 Suggested Answers
SOURCE:
SOURCE: I am after a manual for the Zanussi oven model
Found my answer on the internet
Posted on Sep 07, 2009
The lower element in my oven quit working. I replaced the element and still not heating but broil element does.
Hello Patti;
My name is Peter. I am a retired field service appliance technician.
Although I would like to help you, I need your model number. This number is on a label the face of the oven when you open the oven door, or on the side of the door.
The basic operation of ovens are the same, but the design and operating components may be different.
Post your model number and I will help you.
Mar 10, 2016 | Ovens
I cannot set the clock on my candy oven and I dont know the model number
The model number is usually on the side or rear of the oven.
Instructions for the clock are here:
http://www.manualsdir.com/manuals/243352/candy-fdp-231-x-uk.html?page=11
Nov 22, 2014 | Candy FP855 Electric Single Oven
I have a Kelvinator stove over ten years old Model BCSC764K07WBKAC I want to use the rotisery to cook a chicken and dont know how to set up the oven for this operation. Gayle
put the chicken on a stick and spin it in the oven. connect the stick to a bicycle with the rear wheel disconbobulated. set the oven to 420 degrees and pedal. Now can you tell me why my oven wont turn on?????????????????????????????????
Dec 11, 2010 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
The turn table will not turn and the light will not light when I operate the Microwave. It heats fine....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | GE JTP85 Electric Double Oven
How to operate a franke electric oven
hi i just need to know how to operate the oven for general purposes such as baking. I need to know which symbol stands for what. thanks
Feb 07, 2010 | Ovens
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
Miele Microwave Oven M636 EG
Use Miele UK
http://www.miele.co.uk
click Customer Support
then
click Operating Instructions
select File;
  • M616, M626, M636
free download PDF format
May 02, 2008 | Miele DG 4080 Stainless Steel Electric...
Oven temperature
Hi bigg t. I dont know whether your controller is the same as the UK model, but the unit has to be calibrated when a new board is installed. The differential setting is crucial on these models and the instructions for setting it should be included in the box. Hope it helps. Simon
Nov 16, 2007 | Blodgett CTB BASE Electric Single Oven
Oven malfunction
I dont know how old yours is but there was a recall on whirlpool wall ovens due to the dor not closing enough and when in the clean cycle too much hot air was getting into the control panel and causing a thermal fuse to blow causing the oven to not operate. There is also a non resetable fuse in the back that will cause no operation of the oven. So if you did not have the shim kit installed along with a new seal you should call whirlpool and have your model and serial number off the unit to give them and the will tell you if yours needs the updated fix. If it needs it the repair should be of no cost to you.
Apr 01, 2007 | Whirlpool RBS275PR Electric Single Oven
Ovens Logo
1,076 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
