Question about Sharp KS-ZA10 Rice Cooker
I need an operation manual
I bought a Sharp rice cooker in Thailand and need an operation manual to suit the KS-R11ST in english if possible
  • 5 more comments
  • terryw577 Apr 21, 2009
    Yes i under stand that it is most likely a model for thailand but can you send me KS-ZA10 operation manual i just need the cooking times and rice to water chart.
    Much bigger machine that is a commercial machine starting with 10 cup this machine max would be some where near that
    Not good enough i can find more on a cooking web site please do not go any further and dont bill me
    Ok if you can get me the manual no problems
  • terryw577 Apr 29, 2009
    i never recieved the manual that was requested and your last mail was waiting for your contact to get back to me.
    i have been billed already NOT HAPPY
  • terryw577 Apr 30, 2009
    The model KSH711 looks the closest to the size i have can you send me the operation manual for this model rice cooker
    I did not recieve a manual but i did get enought information to cook rice
    Thank you
  • 11,896 Answers
Steps
  1. I need an operation manual - 170px-p1010161_621.jpg Measure the rice with a cup and put it into your cooking pot. Most of the time, rice cooker boxes will have a cup inside or you can use your own scooper for measurement.
    • One cup of uncooked rice will generate roughly one and a half cups of cooked rice.[1]
    • The measuring cup that comes with your rice cooker is not the same size as a standard US measuring cup (240 ml or 1 cup). It's a cup by rice cooker industry standards (180 ml or about 3/4 cup). Unless the recipe calls specifically for rice cooker cup measurements, you'll need to adjust your measurements accordingly.[2]
  2. Rinse the rice. Read the packaging, as some rice does not need washing and is enriched with iron, niacin, thiamin, and folic acid; rinsing may be unnecessary and will remove any water-soluble vitamins and minerals in the rice.[3] Unless the packaging insists that the rice does not need rinsing, however, it is safer and more hygienic to rinse it to remove any pesticides, herbicides, or contaminants that may be present.
    • 170px-p1010162_330.jpg Run tap water in the bowl. While the water is running, stir the rice. Continue stirring until the pot is full of water.
    • 170px-p1010163_65.jpg Tip the pot at an angle and drain the excess water out. Hold the bottom part with your hand so that you can grab any rice grains that may fall with the water.
    • Repeat until the water comes out clear.
    • Drain as much water as you can.
  3. Soak the rice for thirty minutes, if desired. This is not required, but some people prefer it. It may result in stickier rice.
  4. Measure the water. Most rice cooker instructions recommend cold water.[4] How much water you add depends on what kind of rice you're cooking and how moist you prefer it. One rule of thumb is to fill the cooking pot with the same amount of cups of rice you used, with an additional 1/2 cup. For example, if you made 2 cups of rice, pour in 2 1/2 cups of water. There are also graduated marks on the inside of many rice cookers indicating how much rice and water should be added. The USA Rice Federation[3] recommends following the directions on the package that the rice came in, or using these guidelines in a pinch:
    • White, long grain - 1 3/4 cups of water per 1 cup of rice
    • White, medium grain - 1 1/2 cups of water per 1 cup of rice
    • White, short grain - 1 1/2 cups of water per 1 cup of rice
    • Brown, long grain - 2 1/4 cups of water per 1 cup of rice
    • Parboiled - 2 cups of water per 1 cup of rice
    • Still, you can't really go wrong if you just add two or 2.5 cups of water to each cup of rice; you don't want your rice too dry.
    • For Indian style rices like Basmati or Jasmine, less water is needed as a drier rice is desired, use no more than 1 1/2 cups of water per 1 cup of rice. Use only 1 to 1 if you washed the rice previously. It is ok to add bay leaves or cardimom pods directly to the rice cooker to enhance the flavor.
  5. Add a little bit of salt, butter or oil at this time, if desired.
  6. Try to get any rice grains around the pot back into the water and level out the rice. Wipe the outside of the pot with a cloth or rag.
  7. 170px-p1010165_731.jpg Place the pot into the rice cooker. Cover it, plug the cooker in, and press the switch to turn it in. The switch will click, like a toaster, when the rice is done. In some cookers, the rice will be warmed until you unplug the cooker.
    • Don't lift the lid to check on the rice. The cooking process depends on the development of steam inside the pot, so letting steam escape by opening the lid may result in improperly cooked rice.
    • The rice cooker automatically turns off when the temperature inside the pot exceeds waters boiling point (212 degrees F or 100 degrees C at sea level), which will not happens until all the free water has vaporized.[5]
  8. Allow the rice to "rest" for 10-15 minutes before removing the lid. This is not required but is commonly recommended in rice cooker instructions, and is automatic in some models.[4] Unplugging the rice cooker or taking the pot off of the heat for this period will minimize the amount of rice that sticks to the pot.
Posted on Apr 30, 2009
  • 15,935 Answers
CLICK HERE to select a similar cooker sold in the US, with english manuals.
Your model was never marketed to English speaking countries.
Thanks for using FixYa!!
Posted on Apr 29, 2009
    Top Expert:
  • Sharp Master
  • 80,417 Answers
What is the USA model of this, is this a commercial cooker model
Posted on Apr 21, 2009
    Brigadier General:
  • 3,614 Answers
eventually there was no english manual for that model available online but you may try contacting shar direct support here>> Sharp Customer Support: (800) 237-4277
let me knw
  • 3 more comments
  • micromaster
    micromaster Apr 21, 2009
    Sinsomboon Trading Co.,Ltd.
    219 Soi. Preedeepanomyong 9
    Sukhumvit 71 Rd.
    Prakanong Nuar
    Wattana
    Bangkok 10110
    Tel. 0-2711-1204-7
    Fax. 0-2711-1208
    E-mail : victorthailand@hotmail.com
  • micromaster
    this is the only availble manual which i think similar with your rice cooker
    Download Sharp Rice Cooker KSH-777DW Operation Manual
    update me again
  • micromaster
    A study was made of factors affecting cooking time and the relationship
    between water:rice ratio (water content) in the rice cooker method and
    Instron hardness of cooked rice using 10 milled rice samples of diverse
    properties.
    Water:rice ratio for acceptable soft texture (< 10 kg
    hardness) increased with increasing amylose content of the sample from
    1.1 (56% water in cooked rice, wet basis) to 1.9 (68% water).
    The
    spread in cooked-rice hardness values was higher at a water:rice ratio
    of 1.9 (68% water) than at 2.65 (75% water), which was equivalent to
    the water content of rice cooked in excess water for an optimum cooking
    time.
    Cooking time correlated better with starch final gelatinization
    temperature (r=0.75*) than with surface area per gram (r=−0.49)
    confirming the results of earlier kinetic studies that cooking rate was
    mainly influenced by the reactivity of the grain constituents with
    water.
  • micromaster
    hold on, my contacts not replying yet for the copy of that manual, once i got it i email you.
  • micromaster
    micromaster Apr 30, 2009
KS-ZT18 english manual please
English instructions here:
http://www.thaicity.co.th/elctfl/prdct/pdf72.pdf
Apr 04, 2012 | Kitchen Appliances - Others
Please email to me the English manual of KS-ZA101
mcdevito75 here, You should be able to contact Sharp online for this manual.
Jul 09, 2010 | Sharp KS-ZA10 Rice Cooker
I bought a rice cooker SHARP KS-ZA 101, but no instruction manual in English. Where can I get it?
Dear nvpshenichni, If you bought it from Thailand, I will help you to solve the problem Let me check with SHARP here and will leave further info here BRGDS, Twilight0
Dec 28, 2009 | Sharp KS-ZA10 Rice Cooker
I bought a Sharp rice cooker KS-ZT10 recently from Thailand, then I left the country and returned to UK, started to use it but found rice doesn't cook properly, tried to read the manual, but it's all in...
Dear elsakearney, Please tell me exactly what you did ...what kind of rice you cook.... And I will contact SHARP in Thailand for your manual proplem ... will leave further info here ... Normally, it should be no problem with the computerized one .... this model is quite new .... Will help you to solve it ...dont worry BRGDS, Twilight0
Dec 23, 2009 | Sharp KS-ZA10 Rice Cooker
I bough sharp rice cooker form Thialnd and I need english instruction ans recipes
Dear fmtaleb, Let me check with SHARP in Thailand for your problem and will leave info here... normally they provided cooking corner with recipes in their website as well ....recipes is not a big deal.... BRDGS, Twilight0
Dec 21, 2009 | Sharp KS-ZA10 Rice Cooker
English usermanual Sharp KS ZA 101 ricecooker
The solution is that I will find a thai friend that will translate the manual for me....and not ask money for a service that should be delivered with the cooker!!!!!!!!
Oct 14, 2009 | Sharp KS-ZA10 Rice Cooker
Need manuals for Rice Cooker
Let me get that manual from SHARP/Thailand and will contact you via email. BRDGS, Twilight0
Jan 20, 2009 | Sharp KS-ZA10 Rice Cooker
English version manual
visit this site.. this is the manual for your rice cooker.
http://www.sharpusa.com/files/cae_man_KSH777DW.pdf
i hope i helped you!
Dec 18, 2007 | Sharp KS-ZA10 Rice Cooker
Rice cooker KS-P104
hi!
that may be a hard thing to do since you have a japanese manual.\
you can always use the 1:1 ratio for cooking rice though.
1 cup white rice = 1 cup water.
1 cup brown rice = 2 cups water
hope this helps!
Dec 09, 2007 | Sharp KS-ZA10 Rice Cooker
Sharp KS-ZA10 Rice Cooker Logo
270 people viewed this question
Top Sharp Kitchen Appliances - Others Experts
SteveAlaska
Tom Chichester
Are you a Sharp Kitchen Appliances - Other Expert? Answer questions, earn points and help others
