Question about Simplicity Sew Precious SWSP2 Mechanical Sewing Machine
How to properly thread the bobbin
I have the Simplicity Sew Precious but my daughter messed up the manual so I can't follow it. I'd love to find another manual that I can print and see the pictures. But my question is how do I thread the bobbin? I've completely threaded the top however, when I place the bobbin in the hole at the bottom, wrap the thread accordingly (I think) and then turn the wheel towards me one rotation to attempt to pull the bobbin thread through but it doesn't pick up. Pictures on the internet for how to thread a sewing machine are pretty large and clear until it's time to thread the bobbin and then they get fuzzy and small - go figure...
    Problem Solver:
  • 5 Answers
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
Posted on Jul 29, 2010
  • Crystal Dec 04, 2011
    That link no longer works...any idea where else I can find a copy of the manual? Thanks!
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
and here's another Hint that may be helpful:
Dec 29, 2015 | Singer Sewing Machines
Simplicity sew precious parts
try the manufacturers website or google sewing machine parts
May 09, 2015 | Simplicity Sew Precious SWSP2 Mechanical...
What is the bobbin size
go to, look for the name of the machine & then the model
number & it will show the parts for the machine & it should have the bobbins also
Apr 12, 2012 | Simplicity Sew Precious SWSP2 Mechanical...
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
Bobin will not pick up
The most common reason I see for bobbin thread not being picked up is that the needle is in backwards. Or the needle is a little bent (sometimes it's so little you can't see it, but the machine knows!). So start by trying a new needle (size 80/12 is what's used for test sewing on most machines). If that doesn't work, turn the needle 180 degrees and try again -- there is a definite front and back to a sewing machine needle.
Make certain that your bobbins are the exact ones recommended for your machine. Many look similiar, but if they are off even slightly in depth, they will not work. Also, make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case. Each machine is different so check your manual.
Jul 12, 2011 | Simplicity Sew Precious SWSP2 Mechanical...
I have a model SWSP2 and it will not pick up the bobbin thread. I have a manual and load it as it described but it still will not pick up. How does one get it to pick up and sew. Kat
Just check that the needle is in the right way, flat shank to the back. If you've accidentially put it in backwards, this will prevent stitches from being formed.
Other possibility is that the machine timing is out (service time) but try the needle first, it is an easy mistake to make.
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Sep 30, 2009 | Bernina 1008
Bobbin thread
Make sure that you have your thread going through all the proper thread guides when winding your bobbin. It sounds like the bobbin is getting wound with little or no tension and this can make a horrible mess when trying to sew. Take a look at your bobbins and make sure they look nice and tight. If they are too loose and you feel like you are following the thread path properly, just use your finger to tug on the thread a bit during the bobbin winding process to apply some tension and that should help.
Jul 06, 2008 | Brother LS-1217 Mechanical Sewing Machine
How do you thread the machine, top and bottom, please.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Simplicity Sew Precious SWSP2 Mechanical Sewing Machine Logo
774 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
