Question about Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-500MAH not making ice
It got to where it wasn't making much ice because the water filters got clogged. We changed them and it is doing the same thing only it is getting progressivly worse. Over night it made about a quart of ice. Any suggestions? we have tried shutting it off for a few days and starting it back up but no luck. Thanks, GeoffT
  • Jeff Bodine Sep 21, 2007
    I forgot to start with this. When the filters stopped up it started giving us 3 beeps. After we replaced the filters we ran it through the clean cycle. Then I pushed the reset button on the board and it started making ice but not nearly what it did before, and it has gotten worse to the point to where it isn't making any
    Problem Solver:
  • 5 Answers
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Posted on Sep 24, 2007
SOURCE:
Hoshizaki ice machine model km 900mwh low side suction line has ice building up on it all the way to the compressor
Is it making ice? Frost on this line is not that uncommon as it is colder than the air around it. Make sure you have good water flow over the evap plates. machine may just need a good chemical cleaning.
Jun 14, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine continuously drains a large amount of water into sewer drain
sounds like a bad water valve. I say this assuming that the unit is not a water cooled unit. any further info would be helpful.
Sep 05, 2012 | Hoshizaki Commercial Freezer KM-500MAH
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
My machine km 500 maf is now making ice very slowly. every 35 minutes for one load it has not been able to fill the tub up at this pace in over 3 days.
You are not getting enough water.Change the water filter,if it has one,and check the water inlet valve to see if it is plugged
Sep 15, 2010 | Hoshizaki Commercial Freezer KM-500MAH
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Jul 12, 2009 | Hoshizaki Freezer Commercial Ice Machines...
KM-500MAH won't go into harvest mode
The float switch controls the harvest cycle.
Apr 22, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Waterpump of Ice Machine KM-500MAH-E
Always attempt to have Hoshizaki pumps rebuilt when possible. The parts are cheap compared to buying a new pump. Check ebay from time to time I have just started tearing units down and selling the used parts, that are still functional. Sold that pump for $75 last week
Nov 06, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Commercial Freezer KM-500MAH Logo
1,020 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
