Reboot:
The First thing, you need to reboot your system as some time intervals. Within the event that your pc has no longer been rebooted as of late, make a factor to reboot it earlier than taking after any of the approach under.
Foundation Program:
This is broadly speaking the final issue you'd suspect when your system running slow. A standout amongst the most widely recognized explanations behind a slow PC are projects running out of sight. Evacuate or cripple any TSRs and start-up projects that consequently begin each time the PC boots.
Erase or delete Temp Records:
If PC runs programs, brief documents are put away on the hard drive. Erasing these temp records can help enhance PC execution.
Free hard drive space:
Confirm that, if there is no less than 200-500MB of free hard drive space. This accessible space permits the PC to have space for the swap record to increment in size, and additionally space for impermanent documents. This can prevent your Computer from running slow, Windows 7/ Windows 8.
Check Malware and Infections:
Now a days, the malware virus is the major reason for system issues. So use some antivirus scanner for detecting the virus and infection on your system.
Equipment clashes:
Check whether the Device Manager has no contentions. If so, resolve these issues as they could be the reason for your issue.
Refresh windows and drivers:
Ensure that, You having the most released windows and driver refreshes on your system.
Memory update:
If you have had your PC for over two years, you may require more memory. Today, we propose PCs have at least 1GB of memory (RAM) for 32-bit framework and 2GB for a 64-bit framework. By having enough memory for projects to keep running inside memory, your PC won't have to swap data put away in memory to the swap record. In the event that the hard drive light is continually dynamic, it can be a sign the PC is as often as possible swapping data between your memory and hard drive.
PC or processor is overheating:
If your
computer is running super slow, maybe it's time to address the root of the issue! Ensure your PC and processor is not overheating. Inordinate warmth can bring about a noteworthy abatement in PC execution in light of the fact that most processors naturally diminish the speed of the processor to help make up for warmth related issues.
We have given every general reason that might have caused your computer's running a tad slower. If you done any one of the above, then you need to reboot the system again.
These can be due to:
1>Many programs starting up automatically at system startup
2>A virus/malware
3>Some antivirus softwares make the system slower
4>Large pile-up of old & unused files.
5>Not enough RAM
