No heating and no hot water, my boiler won't fire up
My Vokera Linea 24 boiler has no hot water, no heating, and it doesn't fire up, what is wrong, can I fix it myself? Tried the loop filling lever, but the pressure is alright so not sure what to do next.
  • sotiriadou Apr 21, 2009
    thanks psitechnical, I did not understand most of the things you said... am not that technical, but there is a main switch which I turned off for a bit and turned back on, now the heating runs and there is hot water! So many thanks for your response!
  • 71 Answers
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Posted on Apr 21, 2009
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Boiler cuts off after abt 20 secs of igniting,hot water goes cold then reignites ,hot water for 15-20 secs then repeat goes cold, burner goes off then rignites...ect was told ntc thermister problem but...
Yes usually it is indeed the thermostat, or Thermistor, all part of the control circuit. You did not indicate what type of setup you have. I suggest you Google for a thing called a service manual. This will aid in diagnosis, and repair of your system.
Mar 29, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have a VOKERA 24 boiler the Linea range which was working fine until i notes the pressure was a little under 1.5 Barr. I topped it up the pressure with the filling loop every thing was fine. The next day...
Water logged expansion tank ( ruptured diaphram in tank) or wrong size tank. This caused the excessive pressure in the system causing the relief valve to open. Also, air in the system causing flow to stop, Both conditions will cause boiler go out on safety.
Sep 13, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Nov 04, 2008 | Water Heaters
Heating & Cooling Logo
1,409 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
