Question about Dell Optiplex 755 Desktop Desktop Computer
The monitor is working but is showing as a black screen
I work in a school and a child was messing around with the keyboard on a dell 755 and has managed to blank the screen- when you initially turn it on the normal screen shows and then it turns blank. I know how this can be done on a laptop but I have never seen it done on a pc - it is probably a simple key combination. Please could you help.
Hai there
i believe this will help you to solve the prolem, make sure you pc is off open your case and remove a RAM from the slot and take it back again where it was on slot 1 [DIMM 1] and swicth on your pc
if mouse is giving you a problem download mouse drivers from dell company
Posted on Jun 25, 2009
For my brother also happened same check the monitor wire
Posted on Apr 21, 2009
Black screen gx260
are you hitting f2 in time during the boot splash?
Oct 06, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
What's your problem?i have a dell optiplex 755 (tower).. it was working fine.. but one day when switched it on,, it doesnt behave normal.. and no screen was showing on the monitor.. the pc was sho
Welcome to the world of Windows 7. Don't you miss Windows XP? LOL, Windows 7 is a nightmare just like Vista.
Anyway I think it's your Memory. You mentioned moving the memory chips around, but you didn't mention trying one at a time. I think one of them is bad.
Memory ChipRemove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Try just working with one of them in Slot 1 and swap them out in just Slot 1.
Oh, I just thought of something else, Maybe you have bad Capacitors on the motherboard. Remove the Power Cord, Remove the Case. Take a flash light and look inside the computer at the capacitors. They look like little Battery Towers. If any of them are spewing corrosion out of them, they can cause the computer to go crazy just like yours is doing.
Apr 22, 2012 | Dell Computers & Internet
Delll optiplex 755 desktop - motherboard is dr845 13740. Problem with display. When boot up, no graphics on monitor - same as if monitor not connected. monitor checked ok but pc shows no visuals?
I don't know if you have done anything lately,ie; updates to board, cahnge of cables, etc. but first, try shutting down system, unplug your cable for video, unplug tour tower, plug tower back in and restart. If this doesn't work. You may want to try a system restore back to when you had a picture. Try this and let me know if this worked by adding comment or reply at the end of solution.
Dave
Mar 13, 2011 | Dell OptiPlex 755 Motherboard System Board...
Screen Black but Working
It goes black because it went into shutdown due to fault in the inverter circuits, check the 4 transistors in the inverter circuits for shorts, http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 14, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
Laptop compaq N2660 keyboard not working, does this have a keypad
try to boot up machine again. i suspect you keyboard just went hang.
Jul 01, 2009 | HP Compaq nc6220 Notebook
Screen resolution change = black border around small screen
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Mystery icon on Dell Keyboard Model SK 8115
The icon should mean the NUM LOCK is on. All that does is activate the numberpad on the right side of the keyboard. Chances are the monitor's backlight is bad. Try another monitor. You can also get a flashlight, turn it on and hold it very close to the face of the screen. Look closely at the screen, can you see your desktop or login screen? If so the backlight is not working with in the monitor.
Jun 01, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Gx270Screen splits up
Check your video card settings, it sounds as though the setting is set for two displays.
Good Luck.
Jun 10, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex 755 Desktop Desktop Computer  Logo
277 people viewed this question
Alun Cox
