Question about Garden
I have a Rover easy start lawn mower with a tecumseh 50 motor and I cannot find out the model no the only nos I can find is on the crank case they are CTR172 E-62161 S2186C Made in Italy Thanking you Aldo Rover
  • John C Bridgers Sr May 11, 2010
    Hello:
    >>Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug or Above the Muffler.
    >>Since this is a Tecumseh Engine, I have a PDF Site Addy that May Assist you. http://www.tecumsehpower.com/CustomerSer... . >>This Site Addy; http://www.outdoordistributors.com/Tecum... has a Link to a PDF Trouble-Shooting Guide. Simply Select the Free PDF Download for the Tecumseh Trouble-Shooting Guide.
    >>You can View a Breakdown/IPL of this Engine at this Site Addy, http://www.outdoordistributors.com/ and Select the T. Then Select Tecumseh. Then Select Don't have Part Numbers. Then Enter the Model Numbers . Then Select your Model and Download the File for Online Viewing.
    >>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy. >>Thanks.
    Respectfully
    John
  • 351 Answers
They could be on a metal plate around the carbi and tank
Posted on May 11, 2009
What fuel do I put into a Vantage 3.5 Tecumseh lawn mower?
If it has a place to add oil to the crank case, either a dip stick, or a filler opening at the bottom of the engine, then you just use regular gas. Be sure to verify that there is oil in the crank case before running it this way.
Jun 16, 2016 | Tecumseh Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Late 90's Master Craft Tecumseh Prism 4 lawn mower engine... how do I identify the model number
I suggest take photos of it from all sides then show the photos to the mower parts counter guy.
Then buy the shop manual from him. They last forever.
Aug 24, 2015 | Tecumseh Garden
Tecumseh lawn tractor won't crank or start
check the starter relay jump it see if it starts
Sep 18, 2014 | Garden
Engine diagram tecumseh prism 37
Probably cracked, easy to replace. Take model no. off MOTOR not mower to mower repair shop to get primer button replacement kit!
Jun 26, 2013 | Garden
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
My push lawn mower has no spark. It has a Tecumseh motor. What could be the problem?
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Please take time to rate me
Sep 24, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Husquavarna 650 21 RS (650 Series push mower
May be a blockage in the carburetor. If it's a briggs motor or tecumseh motor on it, check the flywheel key. On a briggs if the key is sheared you'll have no spark at all. If it's a Tecumseh and the key is sheared, you'll probably have spark, but this throws the timing off and could possible show signs of wanting to start, but may be pulling the pull cord handle out of your hand when it tries to catch. Be very careful of this. Tecumseh will give you a spark but if the key is sheared then it'll be the timing. Also, check the brake band on the flywheel and make sure the ground wire isn't off or shorted. Good luck.
Oct 08, 2009 | Garden
My Lawn Boy Pull Start is Locked Up... If I take the Pull Start off, it is fine. How do you know if it is the motor. I am able to get the blades to turn by hand. They do not turn easy like a windmill, but...
Remove spark plug before you ever try to turn engine by the blade then turn engine. If it is hard to turn your cylinder it is gaulded and needs to be serviced or replaced. Check with a professional repairman. Did you run engne low on oil?
Jul 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
712 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
