Question about KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid kuds24se dishwasher DOA
We have a 7 year-old KitchenAid kuds24se dishwasher. This morning it died in mid-cycle. All lights on the control panel are out. I have verified the power and water supply. Any advice other than calling for a repairman? I am handy, have multipurpose electrical meter. Thx Guide2u replied "HAve you check the power supply to the control panel? you may need to open the panel and check the circuit." I replied asking for more detailed instructions. Guide2u never replied. Help!
  • Anonymous Jan 04, 2009
    Same problem. Power is out.
Thermal Fuse
Posted on Jan 05, 2008
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Posted on Sep 22, 2007
SOURCE:
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Oct 30, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
Kuds24se dead
Sep 18, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
I have a15 year old KitchenAid dishwasher. My dishes are now coming out with a film on them.
This is due to a detergent issue, you need to run a dishwasher cleaner in it. You can pick some up at any hardware store. The brand I use is called dishwasher magic, you place it in the lower rack and a wax plug melts mid cycle, I would buy atleast 2 of them. Dishwasher soaps have changed and you film is due to the change in detergent
Dec 16, 2010 | KitchenAid Dishwashers
Dishwasher goes direct to clean cycle - skips all other cycles
check your floater. a round piece in the bottom of tub. what detects water
Feb 05, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
KUDS24SE KitchenAid door latch broke. How do I take the door apart
If the door cannot be opened, remove the the outside lower panel. (2 screws at bottom of panel, then lift off. Take a long screw driver (be sure power is removed first!) and push up behind the control panel at the latch at the very top middle of the door. You can them open the door and remove the screws that hold the control panel on. When the control panel is removed you will have access to the door handle and latch pieces. These parts can be ordered through sears partsdirect web site. Good luck.
Jan 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Dec 30, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
KUDS24SEB3 - can't start cycle properly
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Sep 17, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
How do I change door panel and disconnect the control panel?
I am actually looking a stainless steel panel myself. Where would you able to buy one?
Apr 30, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
755 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
