When I plug in my sandisk sansa 1gb mp3 player to the computer I get 'power limit for the port exceeded' coming up on the computer
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
