Question about Bamix Mono Mixer
Blades I got a Bamix mixer at a yard sale and it did not come with the user manual. My question is how to get the blade off that is on it to use another one. I have tried to take the blade off with no success. Thank you.
  • 96rbje Aug 17, 2008
    Where can I buy a replacement switch for my Bamix Model M100?
    ( I am an electrician).
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
Posted on Apr 18, 2008
  • janech
    janech Oct 20, 2012
    My bamix had a stuck blade for YEARS! I just followed the boiling technique. I boiled it for only a minute or less. And with a towel I tugged at the blade, and it slipped straight off !!! thank you soo soo much. :)
  • Eunice O'Mahony
    Eunice O'Mahony Aug 21, 2019
    I too followed the boiling water trick, and after a few attempts, it can free! Thank you!
This totally works! thank you for posting this solution!
Posted on Nov 14, 2008
SOURCE:
What are the Spring blades
they are the shaft end of your attachments. Tha part that fitd on the shaft. So you can squeeze them together with needle nosed pliers if they won't stay on the shaft.
Feb 19, 2014 | Bamix Food Mixers
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
Sep 28, 2012 | KitchenAid KSM5PS Heavy Duty Stand Mixer
One of the blades seems to be firmly stuck in the blender which mean that I cannot use any of the other components
give us a try at www.ctscanfixit.com we can repair all your restaurant equipment and answer any questions you might have
Mar 10, 2011 | Bamix 391100 Mixer
Where do I get new blades for my Household Blending Mixer HA-3058
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Feb 23, 2009 | Food Mixers
I can't remove the blade from my Bamix hand blender
Shaft should be free for rotation that is ok.
Blade will come off with determined force of pull make sure grasp blade with towel to prevent injury to the fingers.
Dec 13, 2008 | Bamix De Luxe Hand Mixer
Bamix slowdown - repair service anywhere out there?
click on the "contact" link in this website http://www.bamix-usa.com/ there's places in Canada & the US to have them serviced. Through contacting them they'll give you the nearest service area.
Good luck, love my Bamix!
Aug 11, 2008 | Bamix De Luxe Hand Mixer
Attachments fall off
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Feb 23, 2008 | Bamix De Luxe Hand Mixer
Bamix hand mixer seems to be stuck
It says in the manual to soak it in very hot water for 10-20 minutes, then try again. This should free trapped food from the shaft
Oct 31, 2007 | Bamix De Luxe Hand Mixer
Open Questions:
Food Mixers Logo
938 people viewed this question
Top Bamix Food Mixers Experts
pcustad
Ruth summersides
Kami
Are you a Bamix Food Mixer Expert? Answer questions, earn points and help others
