Question about Dishwashers
Dishwasher timer sticks and wash cycle does not complete
My Baumatic BDW 2SS will not complete a wash cycle without me manually moving the timer - as it appears to get stuck at various points. I have changed the timer but this hasn't helped at all. What else could it be? The machine is only 3 years old. Many thanks John
SOURCE: Error E1 comes up on dishwasher
E1 error comes up when faucet is not opened. this is shown up when it takes longer filling time.
The solution for this is to ensure that the inlet hose is not kinked or crushed.
Posted on Dec 23, 2008
SOURCE: e4 shows up when i turn on my dishwasher
E4 is an overfill code caused by water pressure problem.
On the base of the unit - (underneath the kitchen plinth) there are 2 black plastic clip panels - each these of with a blunt knife or screw driver and turn off the appliance at the mains. In there you will see lots of wiring etc. Simply get a dish cloth and mop up any water that is in there, particularly at the back left as that is where the sensor that detects the over flow is. Its simply a rubber valve that is boyent and so lifts when water is present. then once most of the water is removed, turn on.The problem would be solved.
TO PREVENT THIS HAPPENING - when you take off the kitchen plinth you will see 2 small clear pipes in the centre - between the 2 plastic panels. These are cable tied. Simple cut the cable tie and feed the pipes out of the dishwasher - place a bowl under tehre if you whish. This will prevent overfloww water enterin the base. BE WARNED BY DOING THIS THE DISHWASHER WILL NOT HAVE ANY OVERFLOW PROTECTION CAUSING POSSIBLE DAMAGE TO KITCHEN AND APPLIANCE. My advice would be to leave it in place but try to prevent overflow - i.e rinse plates first or try a different brand of wash tablets. If it does happen then the fix is simple and you definately do not have to remove the unit as many people imply.
Posted on Jan 20, 2009
  • 7 Answers
SOURCE: having problems with my baumatic bdw dishwasher.
soundts like program card..expensiv in denmark 1/4 of the prise of a new on..tjek fjuses..house..
Posted on Oct 29, 2009
SOURCE: my matsui mf2w/a dishwasher sticks
check the safety thermostat which is located at the bottom of the dishwasher. you have to remove the bottom plate,and then you will find easily the thermostat-KSD201/PF 90. you have to reset this probably.there is a red wax dot in the middle this thermostat, so remove it and use a needle to press a very small button inside. the heating element is working well probably.you can measure resistance on it to be sure.
Posted on Feb 02, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
The dishwasher doesn't complete the cycle and switches off without draining.
Try advancing the timer manually. It could be that your timer is sticking.
May 19, 2011 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Nov 15, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Mar 24, 2009 | Bosch Dishwashers
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Jan 03, 2009 | Dishwashers
Dec 23, 2008 | Baumatic 23 in. BDW10 Built-in Dishwasher
Dial Timer sticks between wash or rinse modes
Hello. Is the water getting hot? Usually the timer won't advance because it isn't getting a signal from the thermostat that is on the bottom of the tub, so it thinks that the water isn't hot enough to go through the rest of the cycle. That is if the water is hot. If it isn't hot then you may need a new heater. You may or may not need a new timer. Try the thermostat first because that is usually the thing that goes out and it is less expensive than the timer. You can order it from www.coastparts.com or www.marcone.com .
Let me know if you need anymore help.
Dec 07, 2008 | Dishwashers
Dishwashers Logo
192 people viewed this question
Top Dishwashers Experts
