Question about Soltek EQ3401A Barebone
Bios upgrade hi please say me a name of website that i can upgrade my bios my bios
    President:
  • 2,022 Answers
See it depend upon th pc config go thru your manufacter name and search on net with the help og google and yahoo or ant other search engine. bye
Posted on Sep 24, 2007
SOURCE:
My bios has a problem need to repair want a nice recovery software
The only place you should be getting a bios upgrade is from Toshiba's website.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Bios drivers. This is called flashing the bios.
Apr 29, 2012 | Toshiba Satellite L655S5058 Notebook PC
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
Hi, my name is prince can any body help me. I have a mother board gigabyte 845 and we can not installed xp. we have done the partition but when system copy the system file from CD the system againt showing...
Are you installing Windows XP service pack2? This is the problem from the bios, upgrade the bios with latest and it might solve your issue. But be very careful when upgrading the BIOS if the proper version of the BIOS is not upgraded it may corrupt the bios and will make the motherboard dead. Download the manual of upgrading the BIOS from the website, you will also get the latest version of the BIOS from there.
http://www.gigabyte.com/products/product-page.aspx?pid=1737#dl
Jun 23, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Where can I find info to setup bios. also how do I upgrade bios
For this you need to know the exact model of your motherboard. Your current BIOS firmware version can be seen in the BIOS setup window itself ( Press DEL key during your system startup to enter into BIOS screen)
Your motherboard should have Flash BIOS so as to upgrade its firmware. All latest motherboards will have this type only. Goto your motherboard manufacturer website and search for latest BIOS firmware for your exact model. There itself you can find the utility required for BIOS. download that utility and using which you can update your firmware. Please do update your BIOS only if it is required.
I hopt his is helpful to you
Dec 31, 2009 | Computers & Internet
I need a bios upgrade. I have a PT800DBP Motherboard Motherboard: CPU Type Intel Pentium 4A, 2833 MHz (7 x 405) Motherboard Name Unknown Motherboard Chipset VIA VT8763 Apollo PT800 System Memory 512 MB...
boot the pc from cold, note the long identifier number - it contains a 2 character identifier for the board manufacturer. For more info go to the Award bios website, it has a better explanation of this. From there you will be able to either download new BIOS from there, or the website of the vendor/manufacturer.
May 02, 2009 | Computers & Internet
BLue screen BIOS problem
i) i would directly answer to ur question: upgrade BIOS, initially find motherboard make(company name), version and few other details and visit that company or motherboard website.
ii) they will provide BIOS upgrading software for your motherboard or what we call firmware upgrade.......
Note: sometimes u may get this software( u can download it) , otherwise u have to online update which            will do online BIOS update
Thanking you
M. Sridhar
Jan 31, 2009 | Evesham Axis PC Desktop
Windows Vista
hi there
There is 2 ways to do this, firstly you can create a floppy disk with the updated bios flash file on ( not recommended to a novice ) or reinstall XP and updated the bios by downloading it from the manufacturers website and installing it that way. After that you can install Vista.
good luck
Jan 21, 2009 | Toshiba Satellite M35X-S1142 Notebook
Mastermarte
The newest versions of the firmware are on the intermec website. You will have to register in order to download, but a fake name/address will work...if it is a 740/750 the newest firmware is 4.51 PSM 3.93.1, and if it is a 741/751 the newest firmware is 4.95.1 PSM 4.06. the 760 and 761 have different versions of firmware depending if it is GPRS or CDMA.
http://www.intermec.com/support/downloads/index.aspx
Nov 06, 2008 | Intermec 740
Error 162 there is not actulization of the bios
To find your BIOS upgrade you can do one of the following options:
1.Identify your Intel motherboard model via our Award BIOS or AMI BIOS id's tabs
2.Find a(n) Intel BIOS upgrade via the Links tab on the official site.
3.Run the BIOS Agent scan browser plugin
Jun 13, 2008 | Computers & Internet
Issues in Upgrading BIOS
Actually, your motherboard is a GA-7ZMMH, which we were lucky enough to see in the BIOS ID string. You can find the latest BIOS's from Gigabyte's website at: http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1315 It looks like you're on the F5 rev. I would suggest the F10 rev, and only go to the F11b rev if you need the support for the Athlon XP 2600+. If you are not upgrading your BIOS for CPU support, or you do not need to support a CPU faster than the Athlon XP 2200+, then go with the F10 rev.
Sep 03, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Open Questions:
See all Soltek EQ3401A Barebone Questions
Soltek EQ3401A Barebone Logo
104 people viewed this question
Top Soltek Computers & Internet Experts
Ekse
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
