Question about Hitachi 36CX39B 36" TV
Television pictures my television pictures are starting to turn green. First it was 1 channel, now more channels are doing the same. Please help.
  • Anonymous Feb 04, 2009
    I have the same problem as above. Half of the picture screen turns green. What is causing this and can it be fixed?
    Problem Solver:
  • 8 Answers
Manual demagnetizing is all you need. this discoloration is cause of some sort of magnet the been placed near your unit.
a TV has a automatic degaussing coil which in every time you turn your tv on it realligned the pospor of the crt.
since it a huge discoloration you need a manual degaussing process which some service center provides.
Posted on Apr 07, 2009
    Genius:
  • 1,153 Answers
Is this green all over or just in one corner? If all over then depending on the set, which I don't know what kind or size. It means something if its a big screen or direct view.
Posted on Sep 21, 2007
SOURCE:
How do I get my Coby 15" hdtv to work with my
slide the switch on the top of the remote over to tv hold select and mute at the same time the green light on the top of the remote will blink green twice then press 9 then 9 then 1 the light on top will blink again then press the channel up button untill tv turns off then press select if you missed the code do the same steps but instead of channel up press channel down till the tv turns on it will only be a 1 or 2 pushes on the channel down if code was missed let me know if this helps
Oct 27, 2010 | Televison & Video
My 50" panasonic tv screen goes completely green I turn off tv and restart and the picture is still great, but it is doing this more frequently
my 50' panasonic some channels are in another lanuage then some channels have no volume the people mouth are moving but no words then some channels are good.
Oct 03, 2010 | Panasonic TH-50PH9UK 50 in. Plasma...
I can not find the channel for Dish Network.
This hopefully is resolved for you, but here are some easy steps if you ever run into this problem again. If you are at TV1 where the receiver box is located:
You want to make sure that the tv is on channel 3 or 4, and usually on an input. Since the tv says Channel unavailable, it sounds like you do need to be on an input. Try video 1 or 2, or cycle through your inputs.
If you are at TV2
You will want to make sure that your tv is on channel 60 or 73, and you will want to make sure that the receiver box has 3 lights on the front. (Blue, green, yellow.) You will need all 3 lights ont he receiver box for the TV2 to show a picture. I hope that this helps.
Becki Barned
DISH Network Customer Service
Jul 12, 2010 | Olevia LT27HVX 27 in. LCD Television
How come I get green screen on my HD but I still have sound?
Make sure the sord is good. It can be that it is not plugged in tightly. If it has another input, try it on that one.
Aug 15, 2009 | Insignia IS-LCDTV32 32 in. Television
Green picture with horizontal green lines...
John,
First, Id like to know how old is your unit? Also, the lines indicates in issue with regards to the lifespan of your tube. The dominant green color has something to do with a malfunctioning ray gun of your tube. However, i had encounter a unit that was resolved by simply resoldering the circuitry of same problem.
Why dont you try to resolder the board first.
Response is highly appreciated.
chris
Mar 29, 2008 | Toshiba 32AFX61 32" TV
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Hitachi 36CX39B 36" TV Logo
102 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
