Question about IBM IntelliStation Z Pro 6221 PC Desktop
I have the same problem...tried fixmbr, new drive, chkdrv /r....i have 2 intellistation Z pros...happens with both of them.
  • Starfish Phoenix May 11, 2010
    Sorry what happened to them?
  • 184 Answers
Try chkdsk /r
Posted on Aug 04, 2009
Usb boot intellistation
Are you sure you have the USB set as a bootable device? I mean is there boot software on the USB device?
Apr 19, 2012 | IBM IntelliStation M Pro 6218 PC Desktop
I have an IBM Intellistation M Pro (6218-cto; it
I can't installation windows Xp to my PC IntelliStation M Pro 6218,my SCSI drive not detect in Windows setup
Oct 05, 2009 | IBM IntelliStation M Pro 6219 PC Desktop
No audio output with winxp sp2
download the rihgt drivers for your motherboard.
try this one:
http://www.drivershq.com/Drivers/Devices/IBM-IntelliStation-M-Pro-SoundMAX-with-audio-Drive/1916/19/Drivers.aspx
Aug 06, 2009 | IBM IntelliStation M Pro 6849 PC Desktop
Problems with Intellistation 6223 Power Supply?
As this is the first time powering up, check the 115/230V switch on the back of the machine to ensure it is set properly. Then if you're ok going inside the PC follow each cable to it's connector and make sure all are connected firmly then try to start the pc again. If this doesn't work it's likely a dud.
These power supplies are cut to a funny shape so you do have to replace them via IBM. You can take it to any IBM service center or got to:
http://www-304.ibm.com/shop/americas/content/home/store_IBMPublicUSA/en_US/parts/parts_main.html
check for part exchange discounts and then submit, on the next page it will ask for the IBM part # which will be on a sticker on the power supply. The part is fairly easy to swap out if you're at all handy with a screw driver. If you're not, call the 800 number on the above page and ask them for the closest service center.
Hope this helps FixYa,
Chris
May 13, 2009 | IBM IntelliStation Z Pro 6223-42U PC...
Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
Apr 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
(please i'd really appreciate help?) acer aspire 3680 !
sir,,
i think u got an boot up problem,,only if go into windows we get an interface to solve the prob..
if it cums b4 loaidn the OS..then only way is to use boot cd
thank u
Jul 05, 2008 | Acer Aspire 3680 Laptop
Need help
Your boot record is corrupted. You'll want to boot to the Windows 2000 Recovery Console.
http://support.microsoft.com/kb/229716/
Try running the chkdsk /r command first. It may take about 30+mins to finish. If that doesn't get it, then you'll want to try fixing the boot record:
command-> FIXBOOT loadTOCNode(3, 'moreinformation'); fixboot drive name: Use this command (where drive name is the drive letter where the boot sector will be written) to write the new Windows boot sector code on the boot partition. This command fixes problems where the Windows boot sector is corrupted. The Emergency Repair process also fixes the boot sector. This command overrides the default of writing to the system boot partition.
command-> FIXMBR loadTOCNode(3, 'moreinformation'); fixmbr device name Use this command (where device name is an optional device name that specifies the device that needs a new MBR) to repair the master boot record (MBR) of the system partition. This command is used in scenarios where a virus has damaged the MBR and Windows cannot start.
WARNING: This command has the potential to damage your partition tables if a virus is present or a hardware problem exists. This command may lead to inaccessible partitions. Microsoft suggests running antivirus software before using this command.
The name can be obtained from the output of the map command. If this is left blank, the boot device's MBR is fixed, for example:
fixmbr \device\harddisk2 If Fixmbr detects an invalid or non-standard partition table signature, it prompts you for permission before rewriting the MBR.
Jan 17, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
IBM IntelliStation Z Pro 6221 PC Desktop Logo
99 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
