Cooktops Logo
Brian William Robinson Posted on Oct 02, 2013
I have lost my login information - Cooktops
jason johnson
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 02, 2013
jason johnson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
Helped
2183
Points
22
There should be a FORGOT MY PASSWORD option click on it put in email check email and follow instructions
Where can I get a replacement handle for some kind of stove?
if you want information you have to give information and some kind of stove is no good
go to the service agent for the brand of stove and get it from the spares department
Feb 24, 2016 • Cooktops
How do I reprogram a Frigidaire stove/oven after replacing the eoc?
Thank you for your post, Roy!
Based off the information you have provided you need to reprogram your Frigidaire range because you have replaced the oven control. The best way to reset your range is to disconnect power from it for roughly ten minutes. If that does not help resolve your issue you may need to have another electrical component changed and I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
316065306how many watts to run this range
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
Member log in
Login to what/where? You obviously managed to login to FixYa.
Feb 01, 2014 • Cooktops
Can't login
Oct 23, 2013 • Cooktops
Sparking Devizes keeps on going
Although you provided no information as to the make or model of your unit the premise is the same.
Check you voltage at the wall for polarity, if reversed this will happen. If not has this unit been serviced before, if so is it possible it was miss wired? Now to the cooktop, either you have a sticking burner switch causing this or no flame to cut resistance from the electrode (depending on model of course). Not every cooktop works the same. With this being said, give me some more information and I will be glad to assist you.
Thanks for your time.
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 18, 2013 • Cooktops
Change fuse cooktop electrolux
Hello mons_sorense - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
I have a GE Profile cooktop jp930 (less than 5 yrs old) that appears to have lost all power. It was working fine when I turned it on and about 10 minutes later it lost power. I checked the fuse box and...
first check if power is getting to the cook top(there should be a box outside where the wire goes in. After that you have to check if the power makes it to the main board/connector to see if the individual burners are working. My guess is that there is a loose wire at the connection they redid when you redid your counters
I lost my book for my jennair stove and I want to start my self cleaning oven
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
2answers
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
