Question about Chrysler Sentry Key Immobilizer Bypass for Remote Start
Chrysler Voyager Sentry Key Immobilizer System Problem
Does anyone know if there is a bypass system for these compatible with a '98 model? And who would supply them in Australia?
The car randomly immobilizes when starting it. Mechanics dont know what the problem is and want to go through a process of replacing things at considerable cost. Its going to be cheaper to bypass it if possible.
  • 2 more comments
  • pixiefreak Feb 01, 2010
    Thanks for your response. The key is grey.
  • pixiefreak Mar 03, 2010
    We do have 2 working keys and still need to bypass it. Is there some way we could contact you through email for more details on buying the kit from you?
  • MECP Guy
    MECP Guy May 11, 2010
    I can get it for you but first is your ignition key black or grey, because if it is grey you have a transponder but if it black then this will not help you
  • Steve B Jul 26, 2012
    I am in the same situation, I have 2 grey keys. and having issues and need a bypass.
  • 344 Answers
If your key is grey, and you would like to bypass the transponder system you need 2 working keys to program it, this kit comes with a bypass box, and a transponder loop, and only has 2 wires to hook up. Let me know if you still need to bypass it
Posted on Feb 02, 2010
    What is this solution to bypass the transponder system? I am having a similar problem.
How can i bypass the skim made by siemens
There is no way you can. The immobiliser is there to stop EXACTLY what you are trying to do. There is a chip in the key, a chip in the ignition lock and if both are present the ECM releases power to the ignition system.
Mar 24, 2016 | 1997 Dodge Stratus
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 | Televison & Video
1999 chevy 3500 et starts then quits some times it will start back up some times it wont
Spray a little bit of fuel in the intake if it runs by doing that your fuel pump is most likely out. , Thats what my 1994 GMC did to me as well.
Nov 07, 2013 | Chrysler Sentry Key Immobilizer Bypass for...
Is there a way to reset the Sentry Key Immobilizer System for the 2008 chrysler sebring???
What do you mean by reset? If there is a fault, you will need to diagnose what is causing it. Is the red dot light staying on solid or blinking? SOS Diagnostics
Sep 11, 2011 | Chrysler Vehicle Parts & Accessories
I changed my battery, and now my key is not recognized by the computer what do i do?
Make contact with your local Chrysler dealer or if it`s an after market install look at the manual, if you don`t have it, find out the brand then go find them on the web for more information/downloading the manual.
Hope that helps...
Dec 21, 2009 | Chrysler Sentry Key Immobilizer Bypass for...
Sentry Key system won't let me start my Jeep Grand Cherokee
get a new key. you can easily bypass your alarm to ignition conection, worked for me!
Feb 12, 2009 | Chrysler Sentry Key Immobilizer Bypass for...
Re. Instrument Problem of Chrysler Voyager
try to disconnect the battery for 10 min and reconnected should come back to life
Dec 28, 2007 | Directed 04' and Up Chrysler Sentry...
Chrysler Sentry Key Immobilizer Bypass for Remote Start Logo
2,494 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
