Question about Dishwashers
It's a DD 603SS. It beeps and there is a U3 message in red on the outside button, and inside the "rinse", "fast" and "delicate" buttons are all flashing red. Help!
  • redasylumcp Apr 21, 2009
    Yes, it sorted out the problem. Thank you.
  • 527 Answers
Sir,
This is an emerging issue that Fisher Paykel engineers are studying. They believe the valve changes pressure and the dishdrawer's control board thinks its going to flood. The fix is to replace the fill valve, PN 526850. Order new clamps, too, PNs525466.
First have the unit turned off. Then open up the drawer thats givin you trubbel.
The badge ought to be lit.
Now simultaneously press those static touch pads on each end of those led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.
Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure here like about 50 - 70 psi you want ta select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
If you have an integrated model (you know.... matching your fancy smancy kitchen cabinets?)
Listen for a Hi or Low beep instead of looking for a display in the badge window.
this applies to 602's only. The 603's got smart and figgered out the difference all by themselves
check this link for more info....
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Apr 21, 2009
U3
The dishwasher is filling up too quickly compared to what the controller expects. Try to turn down the water inlet tap under kitchen sink and check. Also see if the water pressure setting in the dishwasher is HP for normal mains water pressure. See
DD603 U3 fault code
Feb 10, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i unlock drawer
hold the lock button in. There is a 2 stage lock. first beep locks the key pad. if you keep holding the lock button down it will lock the draw. Hold the button in for the second beep.
Mar 23, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer works but bottom drawer shows code u3 and bottom drawer started leaking water before the u3 code showed up
U3 code generally relates to drain pump blocked. This could mean the water is not able to drain out. Leaking of water is not a good sign. Shows the vacuum seal is not working.
Clean the drawer door from inside and make sure the seal lining is sitting properly. Also the filter plate and the motor cavity needs cleaning. You will need to see the user guide on how to do this.
Nov 02, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw on our dishwasher isnt working .bottoms fine.wont start just beeps and the numbers /display is jumbled
If this has stopped working suddenly then most likely the controller on the top drawer has packed up. Before panicking, take a clean moist kitchen wipe and clean the edges inside around the drawer including the touch buttons inside. Sometimes the grime confuses the controller. Best of luck.
Oct 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel DS605 starts cycle, stops, beeps, shows U3 error.
U3 means the tub filled to quickly or the water failed to drain. Do you have very high water pressure? are you using the wrong detergent? eg you can't use tablets (powerballs) etc in the unit. Try putting half a cup of white vinegar in the tub to kill any foam. Check there isn't anything stuck under the motor rotor inside the tub and the there's no signs of damage. Put the drain hose in a bucket and see if the water drains ok when the unit starts? If everything seems ok I'd suspect the main motor controller module but it may be worth getting an appliance tech to inspect unit first as it's hard without seeing this unit. feel free to ask any questions. Cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
FISHER PAYKEL DISH DRAWER U3 FAULT CODE
LP is a setting for Low pressure. To reset your pressure to HP, hold the Programme and Eco touch switches simultaneously for 5 seconds. Once the setup mode is entered a beep is emitted and
the LCD is red with ‘HP’ or 'LP' displayed. Push the Start/Pause button to alternate between HP and LP. and push the power button to exit.
Sep 14, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher&pakel dishwasher
i would call the company number to ask
you could have a problem if it is a push button type controll and could have gotten dirty behind it
Sep 08, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Double Drawer Dishwasher
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Jan 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F & P Double Drawer
Are you sure of the model?? flash a U3 the following is from The FP Manual on the DD-603 Model...........
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
