Dell 1700n printer load paper light on and will not print despite paper in tray. Have turned off and on, etc. no luck.
It sounds like the feeder wheels are going out. If you pull out your tray and look up underneath you will see a set of rubber wheels. THey are supposed to lower and feed the paper. I am sure they are still rolling but not lowering all the time. Mine are out completely, can still print by feeding a sheet at a time in the front load slot.
See is there any paper stuck inside. bye
The message says remove paper from the output tray, however, there is not any paper in the output tray as it didn't print to begin with and the yellow light it on. Any suggestions would be appreciated as this is going to be the third printer that has been sent to us after spending time with tech support. Checked all the inside areas and there isn't any paper there. Thank you
Cecked for paper jams and none were located. I even loaded a fresh batch of paper into the printer. No luck.
We use our Dell 1700n as our wireless network printer for 7 computers. Lately, we have also been getting the load/remove paper light on and no printing. There is no paper jam, no problem and once we hit the "continue" button, the print job goes ahead and finishes. Very frustrating.
zelfde probleem
